Mazda Lover
Front wheel hub
So my passenger front wheel bearing is shot. It's pitted on the races in the hub, so I ordered a new inner and outer bearing plus the seal. The thing is I can't figure out how to get the old races out. The FSM seems to say you must replace the hub as well, but that just doesn't make sense.
Is there a good way to remove the inner races?
![]() 2004 Mazda6 V6 5-spd - still waiting on money for a motor 1991 Mazda RX7 NA 5-spd - my new DD with 145,000 miles |
#2 | |
Professional Stick Poker
#3 | |
Mazda Lover
Yep. As you found out Mazda meant for the entire hub to be replaced when the bearings went bad. Therefor they left no provision to remove the races. I love the engineering and thought that Mazda put into these cars, but this and a few other things, make me think they spent too much time with the Ford marketing group.
Looks like you got the answer already, but here's a good FAQ on the procedures with pictures, courtesy of MazdaTrix...
http://www.mazdatrix.com/faq/frontbrg.htm |
Mazda Lover
Thanks, that mazdatrix makes me feel better, I was worried i'd make too big of a notch, but they ground that notch pretty large.
I don't understand why the bearings are sold with an inner race if the idea is to replace the entire hub, but I'm glad it's not too bad to figure out.
#7 | ||
Rep Power: 17 ![]() |
S5s have all sorts of fun must replace items. Engineered for making money.
Got a welder? Throw a bead around the inside of the race. This will shrink the race a little bit and you can usually flip the hub over and bang it on the bench and the race will fall out.
http://blog.hemmings.com/index.php/2...bearing-races/ |
#9 |
I have done the welding method and the grind , hammer and drift method. I like the notch method because once the notch is made it is ready for the next set of bearings .
#10 |
Mazda Lover
I did the notch method last night. It worked out pretty well, but it definitely took more time than I initially anticipated.
#11 |
Another option is to place the entire hub in the oven at 200*F for 10 to 15 minutes. The aluminum hub expands faster than the steel bearing race. You can then just flip the hub over and give it a good whack with a hammer and piece of wood. The race generally just falls right out. Sometimes a little more persuasion is needed.
#12 |
Rep Power: 20 ![]() |
I took a torch to the hub and eventually the race just fell out since the hub expanded faster than the race. Similar to above, just more targeted heat.
#13 |
Rep Power: 10 ![]() |
Because bearings are generally generic, so that one bearing could fit a host of other things that have provisions for replacement races.
