Old 03-25-2014, 11:16 AM   #1
C. Ludwig
Rotary Masochist
Jacob, did you guys use the inductive pickup or roller speed for your RPM source? Also, was the ramp rate the same for each turbo?
http://www.lms-efi.com
chris@lms-efi.com
502-515-7482
Facebook @LMS-EFI
Old 03-25-2014, 12:13 PM   #2
jacobcartmill
jacobcartmill is on a distinguished road
Ludwig, we were using the roller speed for RPM. in retrospect, i should have used the ignition pickup, but it is pretty close. my rev limiter is set at 7400, which is pretty close to where it cuts off on the graph.
and yes, i made sure the ramp rate was 160 for both turbo setups. (i went to a different dyno shop, so i had to use the ramp rate that the previous shop used to keep them the same).
also, i am just noticing how strange the dyno graph looks because the axes for torque and HP were different. i am going to check and see if i can get a graph with the same axes.
jacobcartmill is offline   Reply With Quote
Old 03-25-2014, 12:19 PM   #3
C. Ludwig
Rotary Masochist
I figured you used roller speed.. Looks like the RPM isn't synched quite right between the two. Hard to do when using the rollers. Looks to me that you picked uo peak boost closer to 1200 rpm sooner rather than 1500. Still VERY impressive.
chris@lms-efi.com
502-515-7482
Facebook @LMS-EFI
Old 03-25-2014, 12:28 PM   #4
jacobcartmill
i see what you mean. so there's a ~300rpm discrepancy between the two graphs.
also, i can post some logs if you care to check them out and give any general input
Old 03-25-2014, 12:37 PM   #5
C. Ludwig
Rotary Masochist
Yes. Whoever mentioned the BW graph falling off and Elliot saying the hotside on the BW was bigger got me interested. The peaks of each graph are the same. The RPM scale is just shifted.
I'd love to see data. Also, if Elliot will weld the bungs in your manifold, I'll loan you a Haltech EGT box and sensors.
chris@lms-efi.com
502-515-7482
Facebook @LMS-EFI
Old 03-25-2014, 01:28 PM   #6
jacobcartmill
here's a graph with the axes matching the dyno from the 6262 setup:
Old 03-26-2014, 09:57 AM   #7
jacobcartmill
ludwig, i emailed you.
