Old 02-20-2015, 08:51 AM   #1
infernosg
IT'S ALIVE!
infernosg's Avatar
Roll bar is going to stay bolt-in. At least for a little while longer. Stopped by the shop on Wednesday and we worked out a plan.
I decided to go a different direction with the radio delete panel. I just sold my "1FASTT2" (?) gauge panel/pod, but not before I pulled a bunch of dimensions off it. Last night I decided I'd try to replicate it in .025" Al without the holes.
Not bad. Not perfect but okay considering I used only tin snips, a vice, some wood, and sand paper. Not a perfect copy because I couldn't recreate all the bends but it's stiffer than my previous idea and avoid permanently altering the radio surround. The current plan is to mount two USB ports for the display and ECU but I can add any combination of gauges, switches, and whatever in the future.
Old 02-20-2015, 08:54 AM   #2
Pete_89T2
Pete_89T2's Avatar
^Much better than previous version. Plus added benefit that you can R&R whatever you eventually mount to it just like you would the stock radio - just pull out the whole unit.
Old 03-16-2015, 09:37 AM   #3
infernosg
IT'S ALIVE!
infernosg's Avatar
I finished some of my interior projects. Radio delete plate with USB ports for the Haltech and RacePak:
That blank space in front of the console:
The switch is a double pole, momentary switch for the Racepak. Last is the instrument cluster:
Can't really see but I shaved off the holes for the rear defroster, cruise control, and rear wiper.
Old 03-16-2015, 10:08 AM   #4
tweiss3
Mazda Lover
tweiss3's Avatar
That's pretty slick.
Old 03-18-2015, 07:15 AM   #5
infernosg
IT'S ALIVE!
infernosg's Avatar
Snapped a few pictures at the body shop. My project got pushed back so they've only just started working on filling in holes in the engine bay.
With the exception of most threaded holes, I had everything that's no longer needed shaved. Why leave the threaded holes? I figure it's best to allow for the most adjustability in the future. I'm not going for a tucked/shaved look anyway.
Old 03-18-2015, 03:27 PM   #6
calicrewchief
Rotary Tuner in Training
calicrewchief's Avatar
calicrewchief is on a distinguished road
I just finished doing this for the first time. Good luck with it. After the fact I regret spending so much time on it, but I guess it was kind of worth it. I'm sure yours will turn out better than mine did.
calicrewchief is offline   Reply With Quote
Old 03-19-2015, 07:54 AM   #7
infernosg
IT'S ALIVE!
infernosg's Avatar
You definitely took it further than I am. For the most part I'm leaving all the threaded holes in case I want to move things around in the future.
Old 03-27-2015, 10:44 AM   #8
infernosg
IT'S ALIVE!
infernosg's Avatar
Update on my silly bolt-in roll bar ideas:
3/16" plates are welded to the main bulkhead on two faces. I think this is one of the strongest points on the car and is inches away from where the rear sub-frame bolts.
Closer views:
Yes, the plates are on an angle because I didn't like how the bar sat with them being flat.
Old 03-27-2015, 03:44 PM   #9
scarsofcarma
scarsofcarma's Avatar
scarsofcarma is on a distinguished road
Cool
Nice progress looking good, any idea when it'll be done?
scarsofcarma is offline   Reply With Quote
Old 04-28-2015, 07:19 AM   #10
infernosg
IT'S ALIVE!
infernosg's Avatar
The body work should be done by June then there's a few other things I need to finish before I build the engine. The target to fire is August/September but who knows.
The body shop is prepping for paint so they needed all the body parts. I stopped by yesterday to drop everything off and took some pictures:
The body is sealed inside and out.
The engine compartment needs a little more seam sealer before any color is sprayed.
I had them bang in one area of the passenger's side of the transmission tunnel. I didn't like how close the Defined Autoworks exhaust manifold was to the body. This won't be noticeable under the carpet.
The shop recommended was bedliner on the bottom of the car. It's thicker and heavier but is MUCH more durable than traditional rubberized coating.
I'm not having the interior painted so it'll stay the dark gray/black of the sealer. This won't be noticeable with the interior put back together.
It's hard to tell from this angle the fenders have been rolled and pulled 1 in. This looks much better than the roll/pull I did on the red car.
The colors is going to be Magma Orange, color code LD2C. It's the VW/Audi color used on the Fahrenheit edition Golf GTi's.
Old 06-04-2015, 06:43 AM   #11
infernosg
IT'S ALIVE!
infernosg's Avatar
No real updates since last time. Got the intake and exhaust manifolds coated by Swain Tech since they sit so close to each other:
I'm going to put a layer of high-temp. paint over the TBC on the intake manifold.
Kid #2 was born back on 5/15 so not much time to work on anything. I did manage to find a couple hours yesterday to work on patching up the stock front wiring harness. Since I've removed so many wires I have to redo just about every stock splice. Replacing the crimp splices and covering with heat shrink tubing looks much nicer than covering everything with electrical tape...
Old 06-04-2015, 12:52 PM   #12
Congrads!
Everything else should be put on the backburner for such reasons!
Since you're going through all this trouble...
And I believe you're building a "race car"...?
Secure your wiring as much as possible.
If you don't like drilling more holes into the car - understandable - to add wiring clips, then you can always use glued or adhesive anchors.
This minimizes the shaking and vibration of the wiring, which WILL eventually fail at one point.
Concentrate especially at connectors and plugs which add more mass to increase the shaking and vibration and are natural fail points.
Old 06-18-2015, 01:23 PM   #13
infernosg
IT'S ALIVE!
infernosg's Avatar
Congrads!
Thanks! Things are settling down into a routine again so I should be able to get back to work soon.
Not a pure "race car" by any means. I really don't know what to call it. I'm building it the way I want to. But I get what you're saying. This is one of the reasons I didn't have any of the threaded holes plugged. There will be Adel clamps everywhere I can use one.
Progress is being made at the body shop once again. Teaser pics:
Old 06-04-2015, 10:52 AM   #14
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
Life does seem to get in the way of completing projects. Keep plugging away at it, we want to see this one when you get her done.
Old 06-17-2015, 03:24 PM   #15
scarsofcarma
That is good advice, I never thought about securing the wiring harness better than stock for that reason, but it makes perfect sense.
That SwainTech coating supposedly works very well, but it wouldn't hurt to add a physical heat shield between the header and the LIM also. Sorta like the ones RB makes for the carbureted 12A's.
