Old 12-06-2013, 11:40 AM   #1
Is anyone is looking or knows of someone looking for S4 or S5 RX7 parts let me know. I'm running out of space to store everything!
You talking about the black interior???
Or you talking about the other gray interior?
Or just parts in general?
I need stupid stuff like the ECU "cover" and the dash metal panel, although I have no idea how much it'll cost to ship something bulky like that.
Old 12-06-2013, 12:14 PM   #2
My5ABaby
My5ABaby's Avatar
Without a turbo, 220rwhp is pretty far out there unless you do some serious porting. In that case, a turbo is probably more reliable and gives you a better ride and potential to make more power.
Community Service Manual
RotorWiki
Old 12-06-2013, 12:20 PM   #3
Not really.
Chris's FB has an RE-W block (non-turbo), S5 9.7 rotors, big port and a Haltech. I think he said it made 185rwhp.
But, being in a lighter chassis, I bet it flies!!!
Old 12-06-2013, 12:37 PM   #4
Standalone EMS + aftermarket (short runner) intake manifold should push it over the 200hp mark.
Assuming exhaust is already efficient.
You can cheat and push the peak HP towards redline and just raise your redline over the stock...
Old 12-06-2013, 01:29 PM   #5
infernosg
IT'S ALIVE!
infernosg's Avatar
Bits and bobs from both interiors. I like the black interior so whatever I can swap from the '89 to the '86 I'll keep. I believe anything involving or adjacent to the auto seatbelts and sunroof in the S5 is different so those pieces (e.g. headliner, a/b-pillars, rear carpet, hatch trim, etc.) won't be used. I do have an unmolested ECU cover from the S4 car that I don't need. I'm not sure what you mean dash metal panel though. Are you referring to the metal framework?
For the curious here are the control/intake/engine/exhaust specifics:
-ECU: Haltech Sprint RE with FFE VR trigger kit
-Injectors: 2 X ID1000's at 50+ psi base pressure
-Ignition: 4 X AEM IGN-1A coils
-Throttle Body: 55 mm IDA-style ITB's
-Intake Manifold: Custom equal length with ~12" runners
-Housings: S4 TII Irons and S5 TII housings with Defined Autoworks "Circuit" street port
-Rotating assembly: S5 N/A Rotors, RX-8 e-shaft, and aluminum flywheel balanced to 10,000 RPM
-Exhaust: Defined Autoworks manifold and custom 2.5" pipe with single Racing Beat presilencer and muffler
Defined Autoworks supposedly made 232 whp at 8700 RPM with the same port job, rotors, and exhaust manifold. They were using a -RE intake setup, had scalloped rotors, and obviously a different exhaust setup. I know my non-scalloped rotors will reduce power but there's no saying what my intake/exhaust setup will do. Honestly if I'm over 200 whp I'll be happy. Also, NoDOHC has demonstrated the ability of the 4-port engines to make impressive torque numbers with a similar arragement.
Old 12-06-2013, 02:27 PM   #6
I'm actually in need for the rear carpet - rear bins or rear seats?
This is the carpet that runs from behind the front seats all the way back and covers the spare tire, right?
If you got the fiberglass bin "framework", I'd be willing to take that off your hands too; I believe this thing can be broken down in half?
I'll take the ECU metal panel, if you're willing to ship it.
I dunno where mines went - it kinda walked off when I installed my Haltech E8. :P
There's a metal panel that spans across the top of the dash board.
It's about 6" - 8" across, but it goes from A-pillar to A-pillar across the dash.
The decrepit plastic front windshield defroster vents sit on it.
When removed, it's rather flimsy.
Are you in a rush you take care of this?
I usually stop all my shipping due to Christmas.
I'd be willing to take care of this after the new year?
That should do 200...
Old 12-09-2013, 08:34 AM   #7
infernosg
IT'S ALIVE!
infernosg's Avatar
Got the rear suspension and drivetrain fully bolted into the silver car this weekend.
Of course I misplaced the nuts for the stub shafts so I'll have to finish that later. New fuel lines were installed before the rear end was put back in.
I think my phone's camera is dying.
Last night I realized I have the line reversed. The feed line should be on the inside and the return on the outside. Shouldn't be too hard to swap already on the car.
Old 01-17-2014, 07:33 PM   #8
scarsofcarma
scarsofcarma's Avatar
scarsofcarma is on a distinguished road
Did the same thing with a friends car once after a motor swap... couldn't figure out why it wouldn't start for a while lmao
scarsofcarma is offline   Reply With Quote
Old 12-09-2013, 11:32 AM   #9
Silver86
now what?
Silver86's Avatar
Silver86 is on a distinguished road
lookin good!
1986 Rx7 coupe - arctic silver - sold
aka - 20bforme
Silver86 is offline   Reply With Quote
Old 12-09-2013, 11:44 AM   #10
Pete_89T2
Pete_89T2's Avatar
It might just be the lighting in your picture, but it looks to me like there is a hint of a kink in the SS fuel lines. Just wanted you to be aware, extra eyes on target always helps - see the red circle in picture below.
Looking good though!
Old 12-09-2013, 12:46 PM   #11
infernosg
IT'S ALIVE!
infernosg's Avatar
Originally Posted by Silver86 View Post
lookin good!
Thanks! Except for that one swaybar bolt the silver car's been easier to work on than the red car!
Huh, I never noticed that before. I'm pretty sure that's an illusion as it'd take quite a lot to kink a braided stainless line but I'll definitely take a look the next time I'm out there. Thanks for looking out!
Old 12-13-2013, 08:34 PM   #12
infernosg
IT'S ALIVE!
infernosg's Avatar
Got bored the other night and decided to take a break from disassembling the red car. Tore the stock cluster apart in preparation for a custom setup.
Old 12-13-2013, 09:59 PM   #13
Ubaru
Ubaru is on a distinguished road
Is that compatable with a 1983 gs ? I need a few parts, i doubt this but wanted to ask
Ubaru is offline   Reply With Quote
Old 12-14-2013, 03:07 AM   #14
No.
Old 12-14-2013, 10:48 AM   #15
Ubaru
question
Ok thanks man. looking good what you did.
