Not much of an update, but I finally went back and fixed all the picture links
![]() Life and a lack of motivation has gotten in the way of this build, but I have made some progress. At least I'm staying true to the title right ![]() Teaser for now. ![]() |
500hp club
Rep Power: 15 ![]() |
Nice build and nice welds.
Im getting better at aluminum tig myself practice makes perfect.
500hp AEM EMS RotaryAutomotive street ported Aviation sealed 13b-rew 20B 20BEEST FD 23A 4 rotor Long gone 72 rx3 drag machine |
#3 | |
![]() You definitely never stop learning. I still have a long way to go. |
Here is how the engine sits currently. Finished the hardlines a while ago, and did some powder coating.
Also dual passed my radiator.
Professional Stick Poker
You actually have been getting something done.
![]() It is looking really nice. Almost too good to hide under the hood. ... almost.
#7 | |
![]() Thanks buddy, at this point I would punch babies to see it back in the engine bay ![]() |
Rep Power: 20 ![]() |
You may want to add a few 'o's to the title. lol
The work looks great! Your hardlines look WAY more professional than mine lol. |
#9 | |
![]() Thanks man. |
#10 |
Made some really good progress on the v-mount this weekend largely thanks to the help of a good buddy.
![]() Initial mock up of radiator. ![]() ![]() Was hoping to use the factory cross brace, but it wouldn't work with the intercooler size I wanted so it and the mounts had to go. Fabricated lower radiator mounts. Really happy with how these turned out. ![]() ![]() ![]() Once the lower mount was done we moved on to the upper. Attached gusseted plates to the end tank, welded a tab on the frame rail and secured with vibration isolators. ![]() ![]() Mocked up the intercooler. The box represents core and end tanks. ![]() A view through the bumper. ![]() I'm gonna run AC and figuring out what to do with the condenser was a huge PIA. We didn't get to the condenser mounts but the hard part of planning it out is done and we have a path forward. Stay tuned for more. Last edited by RXtacy; 08-09-2015 at 07:42 PM. |
#11 |
You know where you can stick that box.
![]() Looks good. Will having the hoses coming out on the front bottom side of the radiator cause any ground clearance issues? It looks awful low, but I'm sure you guys have checked that out beforehand.
#12 | |
![]() ![]() That belongs to the angry one seen below in action. ![]() Those hose niples are no longer used so theyre getting cut and welded. ![]() The fan is the lowest part of the radiater and it is ~2" above the sway bar as it sits. |
#13 |
I figured that's who the asshat responsible for the mindless drivel was.
1988 N/A SE 2+2, dead stock and staying that way. ![]() 1979 SA22C stock? Not so much. http://rotarycarclub.com/rotary_foru...ad.php?t=15585 Last edited by GySgtFrank; 08-09-2015 at 10:42 PM. |
#14 |
Made some more progress. Got the AC condenser mounted.
#15 |
Woohoo! progress. I've been told that when you mount an oil cooler or condenser it should be placed up against the radiator. Mounting it away from the radiator creates turbulence behind the cooler and decreases the efficiency of the radiator. I don't know if that would be applicable for a V-Mount as I can't tell which side the air is supposed to flow through the condenser.
Your mounts make me very jealous.
Bookmarks |
