Old 02-12-2013, 03:26 PM   #1
RICE RACING
Don Mega
RICE RACING's Avatar
Originally Posted by mazpower View Post
What about using the R7420's with water/meth? From my understanding there is still platinum in those plugs, and doesn't that react with methanol causing pre-ignition? Any suggestions for someone running water/meth injection?
That is internet webs bullshit certified there 100% (probably posted by HC or BDC lol
Last time I looked I am the water/meth expert, been running that stuff longer than anyone in a car that works, not just internet posts , all you need to do is read my thread I have on Aquamist and here.....
The suggestion is as it is
R7420 (for any thing and everything)
p.s. IF!!! platinum spark plugs did what some cock smokers on the internet suggest EVERY SINGLE METHANOL FUELED ROTARY would detonate and blow up with uncontrollable pre ignition leading to detonation !!!!!!! FACTS are no such thing happens in 100 % fueled meth cars the only time it happens is if you get the heat range totally WRONG and the element cannot transfer away enough heat to the body of the spark plug, only then will it act as a glow plug! The token amount of platinum by its own does not act as a catalyst unless it is a very fine wire and suspended in free air just like a true glow plug............. Terse reply but I am just totally sick and tired of reading regurgitated shit from people who have no idea of this at all, especially when it is directly contradicted every day at drag tracks across the world where people are running full meth and full platinum plugs, it simply does not get any simpler than that.
www.riceracing.com.au
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
