Old 01-10-2013, 11:43 PM   #1
managed to make my bulkhead today despite the snow / cold! Pictures should explain most of what happened, but it was a road sign, cut to a circle. drilled for the return and feed bulkhead fittings. the two original sign mounting holes will be used to hold the bulkhead down, but i didnt feel like getting the welder out to make the brackets to hold it.
still either one 180 degree fitting for braided line or two 90 degree 3/8 barb to 6AN fittings so i can finish plumbing the system. then ill get the gas tank up and drop the lines to the tank!
Also the fuel pump stuff is done!
