Old 04-21-2008, 08:27 PM   #1
J-Rat
J-Rat is on a distinguished road
Low end power is a wide argument.. I make 400 ft/lbs of torque, which is stump pulling power. Its more a question of how usable the available power is.
Chances are if its a stock turbo and its not spooling then the twin scroll is not working or the turbo itself is malfunctioning. A 2.5 inch system wont choke a stock turbo, nor will it choke a big single, since I am still on a 2.5 inch catback.
Rat
1988 10th Anniversary
554 RWHP, 395 RW Torque
10.7 @ 126!
owner:
www.azrx7.com
Engine built by ARIZONA ROTARY ROCKETS
www.azrotaryrockets.com
J-Rat is offline   Reply With Quote
Old 04-21-2008, 09:19 PM   #2
Rat
I noticed my boost go down to 10psi on a 2.5" catback (now on our NA) mated to my 3" DP and midpipe from 12psi (with the 3" open cat-back single).
Old 04-22-2008, 07:30 PM   #3
J-Rat
Did you re-adjust the boost controller to compensate for the difference in pressure differential? As with anything else on this and other forums, its all up to personal experience. I can hold 25 PSI all day long to the redline on my 2.5 inch catback. Is it optimal? HELL NO! At my HP level I should be more on a 4 inch exhaust.
The thing that bothers me is that the car is STOCK. Even a stock turbo with a pre-cat, main cat, and crappy stock exhaust system should spool faster then that. All things being considered, I am not entirely convinced its the exhaust. It sounds like how my car ran years ago when I thought I would be smart and wire the Twin Scroll open.
10.7 @ 126!
owner:
www.azrx7.com
Old 04-23-2008, 10:39 AM   #4
Boostmaniac
That made me laugh.
Ok, during my general overhaul of my braking system yesterday, we got to the turbo to start removing it and swapping it out with the S5 unit and I made a few notable discoveries.
There seems to be no oil coming out of the turbo, shaft play is minimal to none that I can tell. I'll be able to make a better assessment once it is removed from the car. I did notice something on the compressor wheel, but I need to get a pic to show you, I can't quite explain it on here adequately.
I did see the twin scroll rod and it does seem normal. Maybe it is malfunctioning, maybe it is wired open and I just can't see it. Again, upon further removal, I'll be able to give you all the down low.
If it isn't the exhaust (which should help me out a little bit) then it is either the turbo or my engine. I am praying it is the turbo, I don't want to rebuild just yet. I just want ONE GOOD PULL the way my car is supposed to pull.
The pics should be high quality also, my buddy that is helping me has been bringing over his incredibly awesome camera.
Edit:
Don't laugh at this. I believe in doing baseline pulls on a dead stock car to see where any improvements I make can be found and to also give accurate reports back. This is my baseline pull, dead stock, crappy catback exhaust.
The car was at WOT at 2500, the target window started at 3000. Boost on this pull didn't really hit positive (maybe 1 psi max) till about 3500 - 3800. Yes I know the AFR is pig rich, that is getting fixed very soon. Yes I also know my power peak is 1k higher than it is supposed to be and I can't explain that at all. Also worth noting, this car has NO acceleration until it gets into boost and it still makes power to 8k or higher and it will hold boost the entire way.
Next time, I'll see if I can datalog boost if I am still having the same problem. There ya go, tell me what you think.
-Maniac
Old 04-23-2008, 01:57 PM   #5
If that black, jagged line is your AFR, it's all over the place...
Fix issues like that first, cause that can cause low boost and low power problems.
Old 04-22-2008, 07:18 AM   #6
Boostmaniac
I was leading more towards the twin scroll not working or the turbo malfunctioning, which sucks seeing as that turbo doesn't leak any oil.
Is there any way to test the twin scroll outside of the car or do you have to actually remove the turbo to do it? I've never really thought about messing around with it before lol.
I do believe that piping was 2.5 on the catback system. I will be removing the turbo either today or tomorrow depending on my situation when I get home. I'll run it through some tests and take some pics.
Old 04-22-2008, 07:42 AM   #7
I edited the title of the thread so it is easier for members to see what is in it. Also, it will make a search easier for someone.
Old 04-22-2008, 10:33 AM   #8
Boostmaniac
Thank you kind sir. I did the title mainly to just get some laughs. I didn't think it would go this long.
Old 04-22-2008, 07:41 PM   #9
You're most likely right since he's not boosting when he should be.
No, I didn't change anything, I swapped that catback in to pass visual and have a "modified exhaust" ticket written off.
Old 04-22-2008, 07:42 PM   #10
J-Rat
Could be a crappy turbo too.. I am not there to check shaft play, etc.. Course there would be an appreciable increase in oily residue/smoke.
10.7 @ 126!
owner:
www.azrx7.com
Old 04-22-2008, 07:44 PM   #11
crappy and/or old (high mileage toasty turbo)
Old 04-24-2008, 05:40 PM   #12
Boostmaniac
Ok, after tearing into it and removing the turbo, this is what I found. The turbo was like this when I bought the car.
Yeah, that can't be good in any way.
But the good news is that I already have a replacement.
S5 is on the left.
So, you all think that might have been what was causing me issues?
Old 04-24-2008, 07:58 PM   #13
I think so...
Old 04-24-2008, 05:43 PM   #14
Take it apart and tell us or send it to BNR and have him tell you
Old 04-24-2008, 05:55 PM   #15
Boostmaniac
I'll take the compressor housing off and try to get another pic.
Look at how eaten up the blades are though.
I have no idea how they got bent that way at all.
