Carburetors and Carb Tuning.. All info about old school carb set ups.. |
SR Race Engineering
Rep Power: 14 ![]() |
Waffles - hmmm good
That worked great, I got all the screws loosened up. The modifications continue ...
SR Race Engineering
Waffles - hmmm good
Update
Got the throttle body 90% done. Cut the secondary shaft in half,
hooked up the mechanical secondaries, and simplified the throttle linkage. I may do more on the throttle linkage once I have the rest of the carb stacked up. I want to try and not have to use the existing return spring and teeter totter so the top is easier to get off (ala Sterling). I also still have to fully adjust the mech. sec. too. They're close but it will have to go on the car to get it just right. I also updated the first post as I've complete tasks if anyone wants to follow along. Top view of fully opened butterflys using mech. sec. linked up. Overview of throttle body with simplified linkages and mech. sec. setup. Close up of simplified linkage.
Waffles - hmmm good
A buddy of mine has graciously volunteered an ACV block off plate. I sure do
appreciate it Mike, if your reading this. I hope to have this on for DGRR but the goal is to have it ready for the Mitty.
SR Race Engineering
I make a one piece aluminum spacer for the primary throttle linkage after I remove all that extra stuff. If you want, PM me your address and I'll send you one.
Waffles - hmmm good
Thanks for the offer Rich. I'm fine with the existing stuff I have for now.
I just hope after I finish this project that folks understand how much work and detail goes into one of these. My hats off to anyone that does this as a service for others. Whatever your charging, its not enough ![]()
Bookmarks |
Tags |
12a, carb, nikki |
