stock test strut.
![]() Thats this weeks evening activity... 3 of the 4, 1.5" thick billet Steel disks have the centers bored to be hub centric. ![]() A mandrel is turned on the lathe so I can put it on my CNC rotary table to get all the holes milled out properly. ![]() Also the surface needs milled down to 1" thick, leaving a .5inch thick center section to turn in the lathe and make it hub centric for the rim as well.
Scott Neville 1984 ITA (converting to something meaner) 1984 13B (Wolf 3.x) 1986 EP (Wolf 4.56) 1991 (Stockish engine, Wolf 3.0) 2005 RX8 Auto (Wife mobile) Life=counting the time till the next race... |
Pink Hair FTW
By no means is this my entire list but a poor college girl can't afford the fancy stuff
![]() 1.) Finish painting my summer rims -one down, three to go ![]() 2.) Detail my entire car 3.) New Intake 4.) Change all fluids 5.) Get an epic rotor tattoo 6.) Pack like a girl 7.) Maybe find a co-pilot 8.) Gas n' Go !!! 9.) Avoid tickets and wrecks - this will be my last Dragon run under my warranty so if my engine goes I hope it is on my last run of the weekend
BOILED PEANUTS!!!
Love the color match!! Mine are white now (I need an updated pic). The car is ready as is, but if I have extra cash before hand I MIGHT lower it
![]() www.rotarycarclub.com "The way a Rotary engine makes power is ferocious, much like having a chainsaw under your right foot." |
Pink Hair FTW
DO IT!!!!!!! If I could afford it I would certainly lower mine but i need a new exhaust first - she sounds so quite the 7 guys kid me and constantly asked if it's even running
I'd like to see what yours look like white - I didn't think I would be a fan of the matchy-matchy rims but it's growing on me.
BOILED PEANUTS!!!
here is a pic of mine. I love the look. My wife saw that I posted about possibly doing springs before hand, and that has apparently been changed to a definite. I love my wife, she is awesome!
for the fb
-order new flares -build new motor -get exhaust figured out -freshen up car - new wheels for the 2nd gen, if it goes big if - better tires - clean up exterior - coilovers - sweet stickers
![]() 85 rx7 gsl-se - AA tags/ never ending project will never run |
Gold Wheels FTW
- New tires
- replace SSV valve - Struts or coil-overs - replace neutral switch - finish carbon fiber CAI - attempt to finish carbon fiber upper intake manifold - tune
My Cars: 1974 RX4 Coupe 1991 FC3S RX7 - Sold 2003 ZZW30 MR2 (Rotary swap after RX8) 2004 SE3P RX8 (20B Swap in the works) |
destroy, rebuild, repeat
after 7 years of owning FCs, i finally picked up an FD a coupe weeks ago.. here is the list to get it to DGRR
replace radiator install coilovers replace altezza tails build new harness and install PS1000 get wideband o2 bung welded onto downpipe install wideband o2 gauge and wiring install battery delete abs decide what coils to use replace fuel filter fix/replace gauge cluster rats nest removal/simplify sequential operation install stereo replace broken wheel studs street tune
1993 RX-7 Touring MB, stockport 13B-REW, 9.4CR rotors, T04S 60-1/p-trim single turbo 1986 RX-7 Base project track beast Last edited by 88turboii; 01-09-2012 at 03:55 PM. |
#9 |
counting down till DGRR
I have a short list of things to do.
Just haven't had the time to get on it. I hope to have theses things done before DGRR 2012 1. Change out the solid motor mounts to polly mounts. 2. Replace the trans and rear end fluids with redline fluids. 3. Install lowering springs and then get a alignment done.
-74 RX-4 -84 REW GSL-SE Past rides -05 REW Swapped RX-8 -93 FD base |
#10 |
If the FD is done, tuned, and ready.
SA too far along still Camaro, dont have 3 rotor Repu - hope to have sold by then
I own A few Rotaries and Yes, I have a rotary problem. (SELLING OFF All my parts) 79SA(Respeed Car),93 FD (tweakit) |
#11 |
Rep Power: 20 ![]() |
So Chad, you're actually going?!
1993 Yamaha GTS1000 1992 Celica Turbo AllTrac 1987 RX7 Sport 1979 Yamaha G1, KM24 powered 1975 Dolmar KMS4 |
#12 |
I took the time off from work and plan to go if I can get the FD or SA done.
FD just needs the tuning done, and some small things. SA needs wiring, tuning, tranny mount, and alot more crap
#13 |
Rep Power: 22 ![]() |
No, he is just posting what he could do if he were going
![]() I have to fill it with fuel, throw some 2 stroke and extra quart of oil in the trunk and give it a bath.
#14 |
i already got started on some of mine
1) new wheels and tires-done 2) tune-up-done 3) install full poly bushing kit-50% done 4) replace ripped vert top 5) buy and install roll bar 6) buy/install prosport oil temp and egt gauges 7) wrap header and replace exhaust gaskets 8) possibly buy rotary aviation adapter for omp or make a block-off plate and pre-mix 9) basic stuff like oil change/fuel filter etc. 10) other cool stuff i find that i want before then! Sephitrask i really like the white on white! |
#15 |
Victory Is Mine
Plan A: FD
Get battery mounted Figure out why it wont turn over change trans fluid bleed clutch stiffer spring in WG new turbo return lines with heat shielding tune Plan B: RX2 Brakes Suspension Tune dual weber 36DCD's
![]() www.dealsgaprotaryrally.com 1994 Rx7 White 2001 RZ GT35R'd 1972 Rx2 Orange Coupe 5spd 2006 STi 1986 Buick GN |
