I know my setup is a little but larger than what you want/described, but here it is anyways:
Front 17*8 +35 Rear 17*9.5 +38 I believe that I am running 235 up front and 275 on the rear. I believe struts play an inportant role in spacing. I am running the above setup on ground control/KYB AGX. Hope this helps! |
pictures?
Cant access imageshack from work, so hope this come through lol
Looks good, that's about how i want my wheels to be.
But is it just that you haven't moved the car since you changed wheels, or is it a little positive camber on the front wheels? |
The car hasnt been moved in years lol but to answer your question, the car suspension has not been set/adjusted.
