Old 06-08-2011, 05:08 PM   #31
need RX7
Clean S4 Nutswinger
need RX7's Avatar
I've been working on the car a bit more lately, now that the weather is nice. I don't have a camera anymore (laundry accident...), but there's not much to take pictures of anyway.
- I finally got the engine bay painted, it came out really good for rattle can. I'm now starting to reassemble the bay.
- I'm working on getting the old bushings out so I can replace them with new Energy Suspension ones
- I started breaking down the rear suspension. Miraculously, my diff mount isn't broken.
I have one more batch of parts to order from Mazdatrix, and I have to pick up the parts for a 5-lug swap, then the final assembly will begin. I'm pretty sure I'll have a job soon, so things will move much faster at that point.
Old 11-15-2011, 11:15 PM   #32
need RX7
Clean S4 Nutswinger
need RX7's Avatar
I haven't completely forgotten about this!
My camera got washed, so I don't have any new pictures, but some progress has been made.
- I'm about 90% done with the undercoating. I decided to go with the rattle can. I've used 4 or 5 cans already, it'll probably take 1 more to finish the underside, then maybe 2-3 more for the wheel wells.
- I'm also in the middle of applying Quick Roof to the interior. It's a poor man's Dynamat and supposedly works pretty good. I'm done with the hatch floor and storage bin/rear seat buckets. I still need to do the passenger compartment floor, the rear suspension area, and I'm thinking about doing the roof too (depending on how hard it is to remove the headliner )
- I have almost everything I need to put my engine together, the only part I'm missing is a TII oil pump.
- I also painted the engine block. I just did the whole thing black, I was having a really hard time masking off the housings properly. The painted (dupli-color cast aluminum) intake manifold, water pump housing, front cover, etc, will provide enough contrast to look decent.
- Once I get a set of suspension bushings and a set of engine and trans mounts, I should be able to get it running. Not optimally, but running nonetheless.
- After that, I'll need to get 2 RPM switches so I can activate the 6pi and VDI.
- I'd also like to upgrade to an FD alternator and put in an electric fan for cleanliness' sake.
I aim to have it all done in time to go driving around on the first nice day in spring.
