#1 | |
So incredibly frustrated
Got a new CPU from Mazdatrix Got the engine to manifold gasket replaced Got the mainifold to turbo gasket replaced Have the efan wired properly...though I may go back and put larger gauge wires in Started the car up tonight and it's got a horrible vacuum leak. It whistles and stalls. I was too worn out from helping a coworker with a surveillance system install to mess with it. Guess I'll start taking things apart tomorrow and find the leak.
Rotating Assembly
If the leak is that bad I wouldnt take things apart. Instead, pull the AFM and fab up a cap/plug with PVC fittings from HD or Lowes. Then pressurize the system with your compressor.
Here's a vid we shot of our test setup. http://www.youtube.com/watch?v=3cFiOfUFofo It includes an TMIC bypass pipe so we could get at all the potential leakpoints in the rat's nest and intake manifolds. We also made this vid showing how we used dry ice in a watering can to make seeing the source of a leak easier to find. If you smoke that'll work too. Unless you have a pulsation damper leak in which case you might blow up! ![]() http://www.youtube.com/watch?v=i5Gluq4rGwI Hope those help.
![]() ![]() 90 S5 Vert. JDM Tii with BNR Stage1 turbo. Pineapple Racing street port. Bonez cat-forward. Corksport cat-back with Vibrant UltraQuiet resonator. RTek 2 wZeitronix w/b. HKS EBC. Vis CF Tii hood. 3000GT wing. Ground Control coilover kit with KYB AGX shocks. Red and Black leather RX8 seats. Corksport Odura lip & bumper caps, OEM Tii skirts Last edited by vrracing; 11-07-2011 at 06:12 PM. |
#3 | ||
