Old 06-30-2011, 07:37 PM   #1
730RWHP12A
What is anyones thoughts as far as the listed turbos size considering its going on a mild streetport 13BT.
very laggy with that massive turbing housing
rotaryshack.com
Old 06-30-2011, 09:08 PM   #2
That was my fear. I should have picked up a NOS Holset H1e with the 19CM housing for $375 when I had the chance lol
Old 07-01-2011, 11:52 AM   #3
You really should start a new thread with a proper Title...
That turbos sounds like a T04B, T5/T6 compressor wheel - my specs show 2.032" / 2.750" on the compressor wheel.
It's really too small for a 13B.
It maxes out at around 250 - 260 at the wheels on a DynoJet.
I used to run a compressor upgrade with that T5 / T6 wheel before and managed to make 254 at the wheels on a DynoJet @ 15psi.
I dunno what kinda spool you're expecting, but a 1.15 A/R turbine shouldn't be that bad.
In terms of compressor wheels, I'd try and look for a T04B V-trim or H-trim, 60-1, or T04E "57 trim" or "60 trim".
These turbos will produce anywhere from 300 to 400hp on a DynoJet up to 15 - 18psi of boost on the edge of pump gas.
Old 07-01-2011, 10:13 AM   #4
Found another turbo from the same guy that may be a better fit:
Compressor: .60 A/R T04B Cover, 51.56mm inducer/70mm exducer, 3" inlet, 2" outlet
Oil cooled Garrett center
Turbine: 1.00 A/R Divided T04 Housing with 3" V-Band outlet
Old 07-01-2011, 11:56 AM   #5
Good info. Guess I need to study up more on compressor wheels. But you think the first one listed would work ok?
Old 07-03-2011, 04:02 PM   #6
Yeah I see. I have actually been thinking about this and decided I probably should just explore the limits of my BNR stage 1 instead of going to a bigger turbo.
Old 07-05-2011, 12:22 PM   #7
classicauto
crash auto?fix auto
classicauto's Avatar
FWIW, I've cooked a non-watercooled turbo before.
T04-S, the shaft was blued all the way up to the compressor wheel. Did it happen right away? no. Did it last a good while? Yes - about 35,000kms. Was I easy on the car? No. Beat the ever loving piss out of it daily.
I've always fitted water cooled centers on after that. Any turbo builder worth his salt can source a water cooled center for almost any turbo. For the extra change and two lines I like the added long term insurance of the extra cooling.
But it certainly works without, just works alot longer with. EDIT: espeically a turbo that is sized for response with a relatively small backside, since there'll be more heat retained in that arrangement.
