Old 03-15-2011, 11:15 PM   #1
FC Zach
FC Zach's Avatar
If this helps, here you go.
http://www.hrpworld.com/client_image...ader/766_1.pdf
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 03-17-2011, 08:47 AM   #2
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
I'm running HEIs as ignitors and 2 FORD TFI coils and the sparks is excellent.
The HEIs are just standard 4 prong ones (DR100s) and the TFI coils are
from the boneyard off of FORD F150 pickups. Its cheap and its a very good
spark. I dropped trailing altogether. I have a write up on the other forum
with details.
If you need to run higher than 8K I would recommend HO HEI and better after
market TFI coils or maybe these LS2 thingies folks are talking about here.
Old 03-17-2011, 09:22 AM   #3
FC Zach
FC Zach's Avatar
Yeah I like your set-up, I recommend the TFI coils. The coil referenced up top is pretty much the same thing just an aftermarket fancied-up version. In fact those coils actually come with the standard 2-spade style connection now, reason why my 2 older direct fires are screw-on terminals and the newer trailing is what i just mentioned.
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
