To the OP, so far the talk has been on getting a stronger ignition for better spark output. Just curious if you have gone to the basics and tried spark plugs that required less current? Iridium plugs have a smaller electrode and conduct electricity better then most other plug materials which would result in a hotter spark with the same voltage.
I know when I switched to iridiums the difference was night and day, not only in how the car ran, but also in the life of the plugs. I ran through b10egv plugs every couple of months, and have been running the same set of iridiums for 2 years now. They were expensive initially, but have more then payed for themselves in the 2 years running them. I don't have a great ignition system, just a twin power, 10mm wires, stock coils, and iridium plugs, but I have never had breakup and it lights my 750cc/min water injected rotary running 26 psi and 10.9:1 afr's just fine. Maybe I have some power left on the table, but that's okay the car is dangerous enough.
500+ HP thanks to: ![]() Fast reacting IAT sensor thread! Mechanical Pre-turbo Water Injection Thread Dual Stock fuel pumps Thread T2 differential swap! |
#2 | |
Don Mega
I'd like to see some numbers from it so we can compare it.
