Old 02-05-2011, 12:57 AM   #1
bumpstart
Banned
bumpstart is on a distinguished road
Originally Posted by bumpstart
waste of time
alum pulley chews out
you cannot tension two belts the same
( so you will find it will soon squeal and slip again )
when the loose one throws,, it often takes out the other
10a 550 belt,, around water pump and main pulley ( no tensioner )
wind it on with same method you use on a bicycle chain
problem solved , permanently,, for around $10
PS
yes this is same trick as the pineapple yahoo belt
yes i have run both dual pulley and the yahoo belts individually for many many daily use years
yahoo is the winner,, it will not cause an issue with bearings ,, but an over-tight dual pulley is not great for the alt bearing
( and does not solve the chew out belt or squeal issue permanently,, take it from a guy with 20 years of DD rotary )
bumpstart is offline   Reply With Quote
