Old 12-05-2012, 01:22 PM   #1
the great state of idaho, in a field behind a farm house
Old 02-25-2013, 01:12 PM   #2
Update:
Nothing really, although I did pick up another Cosmo, just waiting for it to be brought down here to TN.
Started tearing it apart!
Then found some nasty ass rust in a bad spot.
This is where the front engine crossmember bolts to the frame rails. A leaky battery has really fucked it up. Notice that nasty looking nut/bolt there? That is a welded nut that has broken free and it seized. Oh, this also doubles as the front sway bar mount.
Now, this is what it is supposed to look like (picture of the other Cosmo). Much better!!!
Now, the problem is, I have no idea when the other Cosmo is going to make it down here. It is all based on when my step-dad buys a new truck. Lol.
But there is some light at the end of the tunnel. I have found and test fitted all the trim and such, all there. Also I found the glovebox knob, which was a major source of irritation for me.
Other than that, I have replaced the wheel seals and cleaned up the rear diff, including the rear brakes. More to come....
Old 09-30-2013, 06:48 AM   #3
She's about to be sent off for the frame rust repair......
Stayed tuned (whoever is actually watching)
Old 09-30-2013, 08:03 AM   #4
rx7 vinnie
I SEE DEAD PEOPLE
rx7 vinnie's Avatar
I'm watching you from the bushes.....
03 Dodge Viper SRT-10 Vert
16 MB ML350
Old 09-30-2013, 08:10 AM   #5
As usual......
Old 09-30-2013, 08:11 PM   #6
chibikougan
chibikougan's Avatar
Haha watching touching!
Old 10-10-2013, 08:01 AM   #7
Need some parts:
-84-85 big bearing front spindles/uprights
-Electronic dizzy
Sad thing is, before I sold the Cosmo, I had these parts.....then I sold them and now need them again. Whoops.
Kisses
Old 10-10-2013, 10:58 AM   #8
Correction: *CAS.
Quit playing with carbs. Johnny just bought an e6x for $350. From where you are at, might as well spend money that you'd spend with a carb towards going EFI, not as far off as you'd think!
Smoochie Boochies!
Old 10-10-2013, 11:10 AM   #9
I still have a couple CAS's. Problem isn't the cost of the computer, its the cost of everything else.
I want this car to keep the 'old school' vibe. That means ITB's. ITB's are expensive. Plus injectors, manifolds, fuel pump, regulator, fuel lines and in this case, a whole new fuel tank.
That might be down the road, who knows, even a turbo might show up. But for now, this thing needs to get down the road as soon as possible.
Old 10-10-2013, 12:19 PM   #10
meh. external EFI pump (like charles').
Manis/inj/reg/lines are almost free with the scene around here... temp manis now, ITBs later to get old skool feelz...
ext efi pump, 2 INJ gslse fuel setup, well thought out rigged TPS, and whatever manis fit... and you'd be "down the road"... (this assumes you have a center iron with inj bosses, which you'll prob have by the time you swap the bad motor out.)
Old 10-10-2013, 12:41 PM   #11
Who said this motor was bad?
Old 10-10-2013, 03:19 PM   #12
just an assumption. prove me wrong!
Old 10-12-2013, 08:05 AM   #13
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
Is this the intermission? Cool project, not many have the brass cojones to tackle one of these as a project. Why not use the FC front subframe swap for the rack and pinion and brakes? Or are the RX-5 frame rails a different width than the FB/FC?
Old 10-12-2013, 08:12 AM   #14
From what i know, the FC subfrsme is too wide. I will be utilizing FB big bearing front spindles and struts. This will require wheel adapters in the rear, but thats fine. If someone would measure the mounting point width of an FB/FC subframe for me, I'd have confirmation!
Old 10-12-2013, 08:22 AM   #15
GySgtFrank
GySgtFrank's Avatar
Hmmm. It just so happens that I have one sitting in the back of the pickup at the moment. Be right back....
... the front mounting holes are 31 inches center to center and rear holes are 31 5/8 inches center to center. If Whizbang can shoehorn one under an RX-2 I would think an RX-5 should be doable.
