Old 12-17-2010, 11:37 PM   #1
Originally Posted by sen2two View Post
So any thoughts about adding a fuel injector there. Maybe block off the original primary position, and use this location as my primary injector position?
Not a good idea...
Fuel injectors are positioned in (narrow) intake passages to take advantage of the higher intake velocities.
You stuff the fuel injectors into the rotor housings, and you lose a lot of the atomization due to the inferior intake velocity.
Old 12-17-2010, 09:51 PM   #2
88turboii
destroy, rebuild, repeat
88turboii's Avatar
direct injection ftw do iiit
Old 12-18-2010, 12:02 AM   #3
sen2two
KTEC
sen2two's Avatar
Very true.
what I have:
What I had:
Old 12-18-2010, 11:05 AM   #4
hybrid G
hybrid G is on a distinguished road
How about adding water or methanol injection nozzels, to cool the intake charge ?
hybrid G is offline   Reply With Quote
Old 12-18-2010, 10:17 PM   #5
sen2two
KTEC
sen2two's Avatar
Thought about that, but I believe that meth injection works better as a chemical coolant when injected earlier in the air stream to better atomize and remove the heat.
Although I have no idea if that is true. Just a guess I am making. If anyone here has more insight, as if this is a "better" place to inject meth... Speak up!
what I have:
What I had:
Old 01-13-2011, 11:27 AM   #6
NoDOHC
NoDOHC's Avatar
I don't know that the term 'idiot' was entirely deserved...
Either way, I broke my OMP lines on my '86 about 5 years ago. This resulted in me running premix for 5 years. I pulled my tank down a few months back and had no oil residue in it at all (I did have some water though). I do run the OMP now (got new lines) due to my desire to do DOD (Displacement On Demand) at a later date.
Bear in mind that all the bumps on the road and the fuel pump mix the oil and gas in the tank very well. The fuel in the line is moving too quickly to settle out. Besides that- it takes several years for two-cycle oil to settle out of gas in a can.
As to the no injection on decel. The OMP does not inject very much on decel either (the injection quantity is throttle-related - at least on an S4).
Old 01-13-2011, 12:28 PM   #7
ducktape
Hardcore
ducktape's Avatar
ducktape is on a distinguished road
Wow, really? Didn't know there was such a thing as an OMP purist.
I remember once I premixed way too heavily in a stock TII. It ran like ass and smoked like a freight train until I diluted it, but was fine after that.
It's simple really; An OMP can fail catastrophically, premix cannot.
ducktape is offline   Reply With Quote
Old 01-14-2011, 05:35 PM   #8
Rotary Related
Good stuff at low prices
Rotary Related's Avatar
Rotary Related is on a distinguished road
Read post #18 I'm not a purist I use two stroke just like you but use the OMP to dictate the proper amount. I don't add it to the fuel tank as I don't believe it gets metered correctly that way. I have a rotary aviaton adapter. I don't know how much clearer that could be.
Visit us at: www.rotaryrelated.com or find us on facebook
Rotary Related is offline   Reply With Quote
Old 01-13-2011, 01:06 PM   #9
mazpower
Rawr Bearclaw
mazpower's Avatar
My 2 cents...
All I know is every engine I've taken apart that runs premix always looks a little better than an OMP injected system, especially as more time passes between builds. Less gunk in the seals and other build-up.
Then of course this might be from premix being used instead of dirty engine oil. Brian's engine which uses the OMP to inject premix looked just like my engines that run premix exclusively. Modern premix is designed to be delivered with fuel through injectors. I just don't get what Rotary Related is worried about.
Illicit Performance
Rotary building, porting, tuning, chassis dyno services
www.illicitperformance.com
Old 01-13-2011, 01:07 PM   #10
My5ABaby
My5ABaby's Avatar
I've overpremixed before and it smokes a little but I didn't notice a difference in performance.
Community Service Manual
RotorWiki
Old 01-14-2011, 05:46 PM   #11
Funny, I bought a 'vert over the summer that had the OMP blocked off. It had been sitting for over 3 years.
The car I bought was sitting in the garage untouched for 3 years.
The last time the car moved was 3 years ago.
The last time the gas was sloshed around was 3 years ago.
The oil is still suspended. The tank has no sludge in the bottom of it. In fact, the pre-mix helped prevent the tank from rotting away.
There are no ill effects from pre-mixing in the tank. I've seen 4 micron filters not get clogged from pre-mix. When it's mixed in with the gas, it's going to get injected.
FWIW I run the RA adapter injecting some Idemitsu oil, and I pre-mix the same oil in the tank at a ratio of 512:1... or a 1/4 oz of oil per gallon of gas.
Old 01-14-2011, 08:44 PM   #12
NoDOHC
NoDOHC's Avatar
Please don't take offense from RETed, he is a very knowledgeable and intelligent member of the community and I think that he really cares about the rotary community. I think this is why he is so fast to jump on what he sees as misinformation. I know that he comes across a little bluntly at times, but I think that he means no harm by it.
Some day he will stop attacking the person that has the idea that he disagrees with and start attacking the idea - until then, please understand that it is his way of disagreeing and I don't think that he means to offend.
(Please feel free to agree with this yourself RETed - I don't purport to speak for you).
Old 01-14-2011, 09:06 PM   #13
Rotary Related
I'm sure he is a good member. I just think his method was a bit much is all.
Then the topic got way off somehow and I was supposedly using a factory OMP setup? It's crazy in here. Crazy I tell ya.
We could say this: Any oil injection method is fine, if you are fine with it yourself and it's two stroke not four stroke oil.
Old 01-14-2011, 09:39 PM   #14
NoDOHC
NoDOHC's Avatar
I think that it is very important to have discussions about what works and what doesn't, what each of us has found, reasons that we do things, theories on why Mazda did things, deeper engine or suspension theory, etc.
It is also important that we don't pass inaccurate information on because someone may read it and take it as fact.
For this reason, it is good to state what you have found, what you do and why you do it.
As long as we keep these pieces of information as pieces of information and debate in a mature and intelligent fashion, debate is good, as it allows posterity to see both sides of the issue.
