Simply Rotarded
Rep Power: 17 ![]() |
I think S4 BAC valves have an adjustment screw. You need to check/set your TPS sensor via multimeter or test light methods. <~ needs to be done every time you adjust your idle screw or bac.
LunchboxCritter - 91 NA to J-Spec TII - 88 FC Vert - 04 Rx8 Disclaimer: I am not a mechanic, and I did not sleep at a Holiday Inn. DO NOT TRY THIS AT HOME!!! |
