Old 04-02-2010, 10:17 AM   #1
sen2two
KTEC
sen2two's Avatar
OK
-Keith
what I have:
What I had:
Old 04-02-2010, 12:44 PM   #2
My reply was assuming you were going to replace just the actuator, but when I reread what you wrote, it sounded like you were going to replace the entire turbo...right?
Old 04-02-2010, 02:54 PM   #3
sen2two
KTEC
sen2two's Avatar
No, im going to replace just the actuator. From my own personal experience, i believe the wastegate is the enemy when refering to our stock turbos not holding boost up top. (along with the restrictive exhaust housing on the turbo. I also believe this is why S4 turbos do not have such a problem with holding boost with there larger less restrictive exhaust housing. all in theory of course) I could explain it my way, but below is from BNR, the turbo specialist refering to the stock Rx7 turbo.
quoted from BNR's website:
"Upgraded wastegate actuators are the best way to keep the boost level from falling off up in the top RPM. There are a few things that can contribute to this issue. The issue is backpressure between the turbine wheel and engine causing the pressure to push against the wastegate valve assembly. This opens the wastegate premature and causes you to lose boost pressure. The more you port the wastegate port, the worse the problem will be. The solution is a higher spring tension wastegate actuator upgrade. This is a quick and cheap way to generate a noticible power and torque gain in mid range RPM while holding boost up in the top of the RPM band. There are a few actuators to choose from and it depends on what boost level you are trying to run. From there we will help you decide which actuator is best for your application."
The one im using is very similar if not, one of the very ones they use. So hopefully it will work. If not lesson learned... Not that any of this has to do with the intercooler though.
what I have:
What I had:
Old 04-03-2010, 05:21 AM   #4
Crap, I should've just left my reply then... :P
It all depends on what exactly is causing the boost drop?
If it's due to too small of a turbo, then the actuator isn't going to help.
IIRC, a "modified" WG actuator only changes the boost curve by changing the spring pretension to the wastegate actuator.
HKS used to sell these things, but with the advent of boost control technology, there was no sense offering them anymore.
(Electronic) boost controllers have gotten so good, that messing around with modified actuators is a waste of time.
If the wastegate is the culprit, then this can be confirmed by datalogging your boost levels.
Does the boost levels fluctuate at the top end?
If so, then a stronger spring might help.
Most of us do run EBC's, so it's easy to just adjust the EBC to see if this helps.
If the turbo is just too small, nothing you will do will help.
The actuator isn't going to help.
The EBC isn't going to help either.
There is a quick and dirty way to test this, but I warn you it's dangerous...
Disconnect the vaccum line to the WG actuator and see if this changes your boost levels.
If your boost still drops, you're just going way past the physical limits of the turbo itself.
Obvious dangers of overboosting apply here, so be very careful about how much you mash the gas pedal when trying this.
Old 04-03-2010, 09:59 AM   #5
Or, have someone watch the WG actuator while it's on the dyno. I have the same problem with boost levels falling off up top. I don't have a dip, but it does fall off. I suspect that the spring just isn't stong enough. So, next time on the dyno, someone will watch the vitals, someone will watch the duty cycle, and someone will watch the physical actuator to see if the EMAP is overpowering the WG and actuator and venting too much.
If it is, the search begins for a new actuator.
However, I suspect that with such a violent drop like that and then it coming back, it's something else.
Old 04-04-2010, 10:15 PM   #6
If you've got more EMAP than the MAP can hold, it will open the WG even with the spring.
Old 04-05-2010, 12:25 AM   #7
so you're saying the exhaust manifold pressure will force the wastegate door open? I can see that happening, however, a boost controller SHOULD help a little bit. I am curious to see a dyno run with a 10psi setting on the boost controller, I am positive that the power curve would have a lot smaller dip than with just a stock WG/no restrictor in the pressure line.
I guess a BC is not the perfect solution, but it works well enough to merit its use.
EDIT: Anyway, you know a whole lot more about it, so enlighten me with your thoughts.
Old 05-19-2010, 10:21 PM   #8
Ender
rotors excite me
Ender's Avatar
Yes, the exhaust manifold pressure can push past the wastegate, and it makes perfect sense that this problem is increased whenever you make your wastegate port larger (more surface area for the air to press against, yet the same actuator holding it back). A good EBC should be able to all but eliminate that problem since it will keep the pressure to the actuator low until it actually needs to start limiting boost.
'87 TII
rTek 2.1 awaits a tune
Originally Posted by need RX7
360 gamertag: quick Tii
