Show your rotary car build up. Show off your Rotary Car build! |
ziig get those pics on here, I like to see your build.
We will be coming out with Semi-PP Intake manifolds. REDLINE TIME ATTACK Sebring Florida August 14th-15th we hope to be ready by then.
Jimmy FujiRacing www.fuji-racing.com 2010 13B Rotary Miata Semi-PP 2009 REDLINE TIME ATTACK Modified Class Winner Nashville & Englishtown NJ.(Miata Piston Motor n/a) 2008 REDLINE TIME ATTACK Overall Winner VIR Street Class (Miata Piston Motor n/a) 1990 FC3S Street Car |
Our KAAZ LSD in on it's way.
![]() We will be using our own FujiRacing 50mm ITB's and Fuel Rail.
Evil Club Mod
Not to threadjack, but it seems like the FD would be a great fit in the street tire class.
A GTUs would be a nice fit in the Enthusiast class as it seems to only restrict forced induction upgrades. You can make the argument that porting is like a camshaft, so you'd run the largest port that still lets you pass emissions. (Or you just run your car on E85 and drive a bridgeport / p-port to totally annihilate the competition, that should still pass emissions, right?) I just realized, Corvette's will probably own in the Enthusiast class.
Ex-King of the Loop / Captain Guardrail / Master Crab Rapist / Evil Crop Dusting Mod Last edited by Roen; 03-19-2010 at 09:15 AM. |
Evil Club Mod
Ever thought about getting these for the Miata build?
http://www.racingbeat.com/resultset....rtNumber=11061 Which block are you guys using? There have been good results using the RE block in NA form with either 9.7:1 S5 NA rotors or some special 10.2:1 Rotors that KDRotary had used in an NA 20B build. Methinks they were just 10:1 rotors though.
Ex-King of the Loop / Captain Guardrail / Master Crab Rapist / Evil Crop Dusting Mod |
Our FujiRacing 50mm ITB Throttle Bodies just came in from Japan. It has 2 Injector ports per Throttle. I will post pics the next couple of days.
Patiently waiting for pics... I potentially have a rotary powered endurance mx5 project in my future
look at the thread for rotary of the month my miata is on there. I ran 9.7 :1 rotors with the turbo, damaged a rear stationary bearing so i swapped out bearing and decided to drop compression a bit now makeing 310 @ 5 psi
As an owner of a Miata with a blown engine and and ugly FD with a good engine, this is intriguing to me.. cant wait for more info on this kit.
#9 |
Moving along just fine. Car will be ready sometime this year I can promise you that.
#10 |
#11 |
So what progress has been made mate? Dont leave us hanging in the wind. lol!
#12 |
Rep Power: 20 ![]() |
1993 Yamaha GTS1000 1992 Celica Turbo AllTrac 1987 RX7 Sport 1979 Yamaha G1, KM24 powered 1975 Dolmar KMS4 |
#13 |
Pulled my Mazda Torsen Diff. and the alum. housing was cracked. What's amazing is we were able to set the fastest time (over 85 Miata's) @ Hallet Raceway 1.8 mile circuit on 100 treadwear tires 1:28.2 with our 184 whp N/A ITB Piston motor beating the old time of a Supercharged 260 whp time of 1:28.3. Driver only had 1 session and put down the time with the cracked housing which does affect acceleration and possibly handling. I have a pretty good idea what the piston motor can do and can only imagine what the 13B will do.
Note: Last week testing the 1st gen RX712A Semi-PP in the 1/8th and the R&P Gear broke. We will try again this week. Semi-PP is not new to us.
Jimmy FujiRacing www.fuji-racing.com 2010 13B Rotary Miata Semi-PP 2009 REDLINE TIME ATTACK Modified Class Winner Nashville & Englishtown NJ.(Miata Piston Motor n/a) 2008 REDLINE TIME ATTACK Overall Winner VIR Street Class (Miata Piston Motor n/a) 1990 FC3S Street Car Last edited by FujiRacing; 05-19-2010 at 08:21 AM. |
#14 |
In for updates
#15 |
Received my Apex Seals from Japan. I need to get the Iron plates and waiting on the XRP fittings for the fuel rail.
Bookmarks |
Tags |
13b rotary miata |
