Old 09-17-2009, 10:24 PM   #1
NoDOHC
NoDOHC's Avatar
I will start:
I have personally disassembled 3 NA rotary engines that were seized or had bad seals due to carbon buildup in the 6 PI sleeve of the front rotor coming loose.
To fix this, I always take the upper and lower intake manifold off any rotary engine that I get when I first get it and clean everything up, remove any carbon buildup from the sleeves, remove buildup from the intake manifold.
I change or clean my spark plugs frequently because I have seen several rotary engines with the telltale ring around the inside of the rotor housing.
