Old 09-10-2009, 12:24 AM   #1
Originally Posted by dudemaaan View Post
I'm running straight water and tested my mechanical setup with an air compressor and a measuring container for 60 secs. This verified my flow and let me know exactly how much it was. If you just want to make sure the car is using fluid then yeah water will be just fine. No tune needed with water, but if your ignition is weak and you have a large nozzle it will run like crap.
Well I don't remember which injector I got, haha. I think it was the 700cc one, to support 500hp, but I don't remember for sure. Either way, I got my girl's sister's laptop, so I'm gonna install the program on there and follow the instructions to tell it what to read from. I'll test it after that.
Originally Posted by SPICcnmFD View Post
You could tune it with just water and in the winter if you do drive it put a mix in. It won't hurt anything, just richen it up, how much will depend on how much meth you run. There are some guys making 500+ with just water.
I had actually planned on running a mix, then decided I didn't want to tune up for it because if it doesn't work or runs out it will probably lean it out so much it will blow the motor so as of now I'm tuned on just water. For example I was running 35meth/65h2o(blue washer fluid) and it was around 0.5-0.7 richer than just H2O, but it will all depend on how much you are injecting.
Yeah that's exactly why I wanna run water. But that sounds good though, maybe I'll just run a LITTLE bit of meth in there for the winter.
Thanks guys!
