Rotarys Ruin Lives
Rep Power: 17 ![]() |
compression check?
Of I were to do a compression check on a normal compression tester what numbers would I look for?
'88 Turbo II '89 GXL '07 Cobalt: DD |
KTEC
three even bumps is what your really looking for. so three bumps like 30/30/30 = 90. thats ok. but not great.
110 is a nice fresh motor.
Rotarys Ruin Lives
Ok thanks. I knew it was something like that but couldn't remember for sure.
Rotarys Ruin Lives
How do I do it exactly?
KTEC
get a compression tester from any autoparts store pull the spark plug out and thread in the compression tester. (I always remove the fuel pump relay so i no fuel goes in the motor while doing this) then have someone crank the engine while you look at th gauge for the right numbers. do this on the front and rear on the leading plugs.
#6 | |
Compression Tester Man
However, you cannot really evaluate the compression readings derived from such a procedure since you do not know the engine cranking speed during the test. Get a free copy of the factory service manual and read up on compression testing. Better yet, for accurate information, have a compression test done by someone with a proper tester who know what they are doing. |
Rotarys Ruin Lives
I thought it was supposed to be 80 or more for each face. Thanks I wasn't really sure. The help was greatly needed.
If you take both leading plugs out and can get a friend to hold the gas down and crank the car. As long as you have a 550 CCA + Battery, you should get about 375 engine rpm driven on the starter. With the valve removed from the bottom of the compression gauge, watch how high the gauge bounces when cranking. It should bounce to 80-120 psi (110 is good for turbo, 120 is good for NA). With 5,000 miles on a rather meticulous rebuild my turbo engine made 120 psi on all faces, front and rear.
You want to make sure that the gauge bounces rather quickly (goes up, down, up down) any pauses in the needle at zero indicate a bad face. A long pause could indicate two bad faces (bad or stuck apex seal) while a short pause indicates a single bad face (bad or stuck side seal). I hope this helps you a little. Two notes: Never check compression after flooding the engine - it will always read low (60 psi or less). If the engine starts every time, idles well and has good low-end torque, your compression is probably acceptable. Another interesting note on compression: If you have good compression, you can flood the engine (like putting a 3 bar tune in the ECU while using a 1 bar sensor) and after you get the appropriate tune in the ECU the engine will start fine without going through a deflooding procedure. (Needing to deflood all the time is usually a sign of bad compression.)
#9 |
Rotarys Ruin Lives
Awesome thanks a lot guys. What is the hybrid turbo everyone talks about all the time? I have heard of it but don't know exactly what it is.
