help on the way
All the electrical goes through the drivers door then to your passenger door, i would start with the drivers side door jamb wiring. It will be a pain in the butt to play with the connector with the fender or door on the car. If someone put paint on the body side electrical pins that will be sucktackular. Second check out the pins on the passenger door. Been working on these cars for a while now and i have never changed door window motor or power lock motor. i have changed lh door window switches because they fall apart. If you have a 93 and you need the LH window switch use the one from the 94 and up it has the express down feature and it is a plug and play.
