#10 | |
Rep Power: 21 ![]() |
$40 FCD + $200 A/F controller
vs $400 Rtek vs $1100 Haltech ECU. If you're going to rock the stock setup then just stick with FCD and AFC + tune or the Rtek...no point in blowing $1100 on a setup you don't need. As far as the wastegate, if it's jammed or not opening properly then you should replace the components. Any new info on this issue?
![]() Last edited by Phoenix7; 07-08-2009 at 06:33 PM. |
