Old 07-06-2009, 11:21 PM   #1
Black91n/a
Black91n/a is on a distinguished road
You can get organic disks in 7.25" that would be better for semi-street duty, as you'd gain more modulation over a 5.5" race disk. Another thing to consider, get a flywheel for an NA transmission and use an RX-4 or similiar bellhousing, as I'm told it'll bolt up to a TII transmission and works with the smaller NA flywheel size. Should work with whatever T5 adapter you'd have to use as well. The smaller the flywheel, the less the inertia for a given weight, also, it should be able to be lighter by being smaller.
Black91n/a is offline   Reply With Quote
