3rd Gen RX-7 Engine Parts Only Engine Related parts ONLY! |
06-30-2009, 08:23 AM | #1 |
Parting out engine and trans LOTs of aftermarket and stock parts!
Polished UIM $150
Greddy 2 row FMIC w/ HKS SSQ BOV $900 Defi mechanical Boost gauge $130 HKS EVC IV electronic boost controller $150 Single turbo engine harness with FJO injector driver (low miles) $500 Aspec GT3574 turbo .96 A/R $600 Tial 46mm WG $300 Ported rx7store singleturbo manifold with tial 46mm wg flange $150 NEW air intake temp sensor $40 Bosch 1680cc injectors cleaned and flow tested (5) $ 70 each Lucas/RC 120lb injectors (1 pair) $90 Fluidyne Radiator w/ stock fan setup $350 FC leading ignition coil (3) $50 each 5 speed tranny w/ gotham short shifter no grinds $400 Supra TT Fuel pump(s) 2 $140 shipped (each) Big Boy fuel setup (black anodized top feed rails, sard FPR w/gauge and mounting bracket w/ harware. 2 edlebrock 40 micron stainless replaceable stainless steel fuel filters, All lines and fittings required for install. hose is black nylon with SS reinforced braid. This fuel setup will handle whatever you wanna run though it from pumpgas to race gas and even E85. $590 Supra TT Fuel pump(s) 2 $140 shipped Still have more things to list so check back |
07-01-2009, 08:08 AM | #3 | |
I'll update this thread with pics as well as more parts. |
07-01-2009, 08:14 AM | #4 |
Polished UIM $150
Greddy 2 row FMIC w/ HKS SSQ BOV $700 Defi mechanical Boost gauge $130 HKS EVC IV electronic boost controller $150 Single turbo engine harness with FJO injector driver (low miles) $400 Aspec GT3574 turbo .96 A/R $550 Tial 46mm WG $250 Ported rx7store single turbo manifold with tial 46mm wg flange $150 NEW air intake temp sensor $40 Bosch 1680cc injectors cleaned and flow tested (5) $ 65each Lucas/RC 120lb injectors (1 pair) $80 Fluidyne Radiator w/ stock fan setup $275 FC leading ignition coil (3) $40 each 5 speed tranny no grinds $300 Supra TT Fuel pump(s) 2 $140 shipped (each) Big Boy fuel setup (black anodized top feed rails, sard FPR w/gauge and mounting bracket w/ harware. 2 edlebrock 40 micron stainless replaceable stainless steel fuel filters, All lines and fittings required for install. hose is black nylon with SS reinforced braid. This fuel setup will handle whatever you wanna run though it from pumpgas to race gas and even E85. $500 (i'll even throw in a pair of1680cc injectors Also willing to part out the fuel system... Supra TT Fuel pump(s) 2 $140 shipped each Ebay Engine torque damper painted black $50 Thermostat housing with AST delete $50 Throttle body $65 LIM $50 Gotham racing Short shifter $145 BDC ported half bridge REW $2000 Gotham racing polyurathane motor mounts $100 |
07-01-2009, 08:36 AM | #8 |
I fly drones & film crap.
I am interested in the FMIC can you post photos of it?
How many miles... track/dragstrip events on the transmission?
Kevin Last edited by ZGN; 07-01-2009 at 08:38 AM.. |
07-01-2009, 08:54 AM | #9 |
I'll go get some pix of the FMIC now, transmission was rebuilt before I bought the car and I have put about 30-40k miles on it, about 8 trips down the drag strip (never power shifted) and no track days. I've used royal purple synthetic fluid as long as i've had it
07-03-2009, 11:34 AM | #12 |
Update!
Polished UIM $150
Greddy 2 row FMIC w/ HKS SSQ BOV $700 Defi mechanical Boost gauge $130 HKS EVC IV electronic boost controller $150 Single turbo engine harness with FJO injector driver (low miles) $400 NEW air intake temp sensor $40 Bosch 1680cc injectors cleaned and flow tested (5) $ 65each Lucas/RC 120lb injectors (1 pair) $80 Fluidyne Radiator w/ stock fan setup $275 FC leading ignition coil (3) $40 each 5 speed tranny no grinds $300 Supra TT Fuel pump(s) 2 $140 shipped (each) Big Boy fuel setup (black anodized top feed rails, sard FPR w/gauge and mounting bracket w/ harware. 2 edlebrock 40 micron stainless replaceable stainless steel fuel filters, All lines and fittings required for install. hose is black nylon with SS reinforced braid. This fuel setup will handle whatever you wanna run though it from pumpgas to race gas and even E85. $500 (i'll even throw in a pair of1680cc injectors Also willing to part out the fuel system... Ebay Engine torque damper painted black $50 needs respayed Thermostat housing with AST delete $50 Throttle body $65 LIM $50 Gotham racing Short shifter $145 BDC ported half bridge REW $2000 Gotham racing polyurathane motor mounts $100 Aspec GT3574 turbo .96 A/R Deposit Received Pending Tial 46mm WG Deposit Received Pending Ported rx7store single turbo manifold with tial 46mm wg flange Deposit Received Pending Down pipe for single setup Deposit Received Pending |
07-07-2009, 08:34 AM | #15 |
Polished UIM $150
Greddy 2 row FMIC w/ HKS SSQ BOV $700 Defi mechanical Boost gauge $130 HKS EVC IV electronic boost controller $150 NEW air intake temp sensor $40 Bosch 1680cc injectors cleaned and flow tested (3) $65 each Lucas/RC 120lb injectors (1 pair) $80 FC leading ignition coil (3) $40 each 5 speed tranny no grinds $300 Supra TT Fuel pump(s) 2 $140 shipped (each) Ebay Engine torque damper painted black $50 needs respayed Thermostat housing with AST delete $50 Thermostat housing Regular $40 Throttle body with TPS $65 LIM $50 Gotham racing Short shifter $145 BDC ported half bridge REW $2000 Aspec GT3574 turbo .96 A/R Deposit Received Pending Tial 46mm WG Deposit Received Pending Ported rx7store single turbo manifold with tial 46mm wg flange Deposit Received Pending Down pipe for single setup Deposit Received Pending FD trailing Coils about 15k miles on them $55 each Midpipe $150 Greddy PE catback $300 Driveshaft $100 PPF $100 Fuse block with batter cable $65 Engine pressure tester $30 Pineable exhaust porting template $20 shipped If you see something you like Make me a offer. Some prices are OBO! |
