#8 | |
Rep Power: 20 ![]() |
It was my understanding that a higher PSI rating allowed thermal transfer easier through the aluminum. I too, could be wrong... but I will do a google search and see what comes up. http://www.stewartcomponents.com/tec...ech_Tips_2.htm That's about the most helpful link I could find in the five minutes of searching. My theory is this: As the engine heats, the heat is then absorbed by the coolant. As the coolant takes on that heat it begins to become less dense, and by effect become less able to absorb the heat coming from the engine. As the coolant gets to the boiling point, it builds pressure. This pressure forces the heat from the engine to continue to be absorbed at a specific rate. Once the peak pressure of the cap is reached, it vents it to the recirc tank and the process starts all over again. The theory stays the same for high pressure (20 PSI, which I assume is absolutely safe for the engine since Pineapple racing tests their cooling systems to 20PSI to check for leaks). Since the pressure is higher than stock the boiling point of the coolant is raised, which allows heat to transfer from the hotter source (the engine) to the still liquid coolant. Once that is then pushed to the radiator more molecules are packed to the cooling fins thus rejecting the newly absorbed heat, ergo a cooler engine. This is of course just a theory, and I do not have the funds as of right now to fully test it. But if some one does test it I would like to hear the results. I had tons of external leaks when I first started using it. Everything from an adapter being pushed out, to a hose bursting (it was old and already worn). Yet as soon as I fixed all those leaks it seemed to work quite well. I have to drive back down to blacksburg tomorrow because I forgot a few important things for the internship, so I'll report back on the temps of the 13lbs (.8 bar). From what I noticed just on this trip up to Culpeper my temperatures were slightly hotter than what I was used to driving around town with the 20lbs (1.something bar), though temps never seemed to stay around 200F for very long and usually fell sharply after the hill climbs back down to 180-190F.
