#10 |
Rep Power: 20 ![]() |
now I know that's a lot to read, but here's some more food for thought:
What exactly are the benefits of using an NA engine compared to other methods to utilize a turbo? Well, lets first look at the different possibilities to which one can turbo an rx7 (maintaining the same style motor mainly 13B). For the sake of my sanity and the sake of others sanity as well I'll develop it in a list that is somewhat different than most.
Now is it really worth it to turbo charge an NA engine? Probably not. There's a few reasons for this, mainly if you're attempting to make a high compression turbo project it would be significantly easier to pick up a different keg and swap in some NA rotors. The only thing that the NA has that the Turbo versions do not is the 6PI or the VDI system. Which all in all isn't all that important if you consider that the only reason to have those systems is to have a manageable torque curve when you're actually trying to drive. This is accomplished in the 13B REW by the sequentials which provide an amazingly flat torque curve. So here it is: The only reason to actually turbo charge an NA engine is to use a turbo with either the 6PI and/or the VDI system. The benefits? I can't say off first hand knowledge... though I imagine the ability to alter the torque curve would be the biggest thing. But there again that can be done with fancy turbo system by itself.
