Old 04-27-2009, 10:52 AM   #13
Originally Posted by Shadow24v View Post
oh? what are the criteria for a correctly set idle on a rotary then?
AFAIK idle speed is the primary governor for a properly set idle on a piston car....
Look up the procedure in the FSM. I had to adjust the secondary throttle plates as well as the air bleed screw to properly set the idle. I doubt you'll have to do that though since it's usually set and locked from the factory.
