Carburetors and Carb Tuning.. All info about old school carb set ups.. |
Turboed carbed FC
Just wandering. i just got my hand on a bridgeported carbed fc. thinkin i might want to turbo it. its an s5. I know people have done it.
does anyone know of any build threads. or anyone who has done it with good luck.
1988 Fc Vert. Super Stock 1990 Fc Hard top: Brideported 13b, weber carb, 350z wheels w/nitrogen, or 16in BBS meshies, Msd, Racaro Racing Seats, Custom Gauge cluster, custom Intake, Relocated Battery, 3inch header back borla exhaust system, Alpine stereo system, Wire tucked, S4 shift boot&knob, custom Strut bar, And soon to come a Full black w/ gold pearl paint job, powder coated break calipers, all black interior, bride headliner/door panels. ![]() |
#2 | |
Custom User Title
I'm in the process. It's not that popular among FC owners, but FB guys do blow-through quite often. What carb does it have now?
shookmotorsports.com
Which weber are running??
It's pretty easy to setup them up for blowthrough. I used to have first gen that set up a Weber 48 DCO to run blowthrough. The problem that you are going to face is getting a proper sized turbo to work with that bridge port at the pressure levels that a two barrel can work with. |
crash auto?fix auto
Just build a box for the carb
![]() Tonnes of info out there on blow through setups, but if you want real guru information on that - you won't find (much) of it on import forums - if it doesn't have fuel injectors most of them don't know what to do! ![]() Gotta find old school minds for that information. |
ORD - Old Rotary Dude
A Holley setup would be the easiest, but the IDA would turn the most juice. The problem with running a turbo IDA is the float. No one sells a float that can handle more than about 5-7 psi.
Carb bonnets are readily available for the Holleys, not to mention all of the internals can be easily changed to accomodate a blow through setup. |
#6 | |
Custom User Title
I hear the accelerator pump is also problematic for blow-through IDAs.
Even easier than a Holley would be an OER, or even a DCOE with the later-style plastic floats. I'm going to be using the latter. RotaryShack will sell you a carb hat for the DCOE or OER, but I'm cheap so I'll probably make my own.
[QUOTE=nolimitind;80232]A Holley setup would be the easiest, but the IDA would turn the most juice. The problem with running a turbo IDA is the float. No one sells a float that can handle more than about 5-7 psi.
QUOTE] an IDA will make good power when used in a blow through application and i sell solid floats for the IDA, so there is no limit to how much boost you can run.. the accelerator pump circut works fine too.
![]() ![]() ![]() rotaryshack.com |
Well there ya go! Leave it to tha Shack to come through with the solid floats! I searched for years (not lately) and couldn't find even a European, Italian, Chinese, or Japanese supplier for these. I may have to the build that I wanted to do about 5 years ago now.
Another thumbs up for tha Shack! Todd B. |
#9 | |
ive done tons of carb blow through setups for over 18 years.. if you have any questions please ask. to get some ideas click the link http://www.rotaryshack.com/ourcars.html here is a video of how the blow through cars run ![]() http://www.youtube.com/watch?v=fPj2-afWOg0
#10 |
Bookmarks |
Thread Tools | |
Display Modes | |
