FDNewbie Imports Import Rare Japanese Only Parts to USA. |
Tired of the puny stocker oil cooler? Feeling uneasy seeing oil temps on the high side? Or are you a track junky in search for THE MOTHER of all dual oil cooler kits, but haven’t found what you’re looking for yet? Well look no further…THIS IS THE DUAL OIL COOLER KIT FOR YOU.
So what makes the FDNewbie Imports/Intransigent (Auto) Design oil cooler all that & a bucket of fries? - Our kit utilizes only the HIGHEST QUALITY cores of your choice: black Setrabs for the no-nonsense stealth look, or brilliant silver Mocals for function with style! - While the OEM oil coolers measure a mere 5.25” X 8” X 1.875,” our cores measure 7.5” X 13” X 2”, with large 25 (yes you read that right, twenty five) row cores, giving you more than enough in size, surface area, & capacity for your serious roadracing needs. This means better cooling with a larger oil capacity to give you more consistently cool oil temps! - Tried & true Mocal 180 degrees oil thermostat - Aluminum mounting brackets for oil coolers and thermostat - Stainless steel mounting hardware included! - All pre-made and pressure tested push-loc style fittings & lines from the coolers to the front cover and oil pedestal are included. Stainless steel braided lines are optional for a minor fee. ***Why don’t we include stainless steel braided lines in our kit by default? Because your safety is our #1 Priority! While stainless steel braiding protects the lines, the braiding conceals the condition of the line from your view, effectively hiding any deterioration in the line that may be present! Thus, to be safe, these lines must be changed regularly, and hence must be requested by the customer specifically. These lines must also be securely fastened away from any other lines or parts around them, as they will abrade away at anything they are left to make contact with over a prolonged period of time!*** - Test fitted for both the 1993 – 1998 OEM bumper and 1999+ style OEM & aftermarket bumpers utilizing the 1999+ OEM combination lights! - Direct bolt-on, with no fabrication or custom work necessary! And as if that wasn’t enough, our kit is 100% *GENUINE* JDM (…or at minimum, JDM-junkies have put together the kits with their own bare hands haha) Price: TBA. Dealer inquiries welcome. Pics are below. Thanks! ~Ramy FDNewbie Imports Figured I'd transfer this over ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Bookmarks |
Thread Tools | |
Display Modes | |
