Old 02-24-2009, 11:03 PM   #3
well there is another way to do the dry sump. I read a write up about it a little while back. Essentially, you use off the shelf "v8" type stuff. The flat bottom pan is simple to make, then you run your own connections to a moroso dry sump. Ill see if i can find it. I have thought about the setup a bit recently so im curious myself.
http://www.nopistons.com/forums/Thre...ys-t73703.html
