| Introduce yourself!! Tell me something about you and your history with rotary.. |
|  02-20-2009, 08:02 PM | #1 |
| The Newbie Join Date: Feb 2009
				Rep Power: 0  |
				new 2 rotary
			hey im  lookn for info on building a 13b bridgeport carb motor for my ford cortina prty new 2 the hole rotary motor so  ne help much apreciated
|  02-20-2009, 08:45 PM | #2 |
| Respecognize! Join Date: Jul 2008 Location: Δx = ħ/2Δp
				Rep Power: 21  |
			well there are a few things you need to decided. Mostly on which generation 13b. I would recommend use of S4 or S5 13B due to them being the most common, lowest weight and an overall lower cost. For the ease of a swap, if so inclined, you can use a 12a front cover and have the front cross brace if it makes the swap easier.
				__________________ For current updates and event coverage check out Follow on Twitter! @WhizbangRally Whizbang Rally's Webpage | Facebook |
|  02-21-2009, 12:18 AM | #3 |
				Rep Power: 0  |
			cheers . looking at s5 block with s4 rotors could you tell me a bit about different porting, bridge, tall port, pp etc
|  02-22-2009, 02:38 AM | #4 |
| Rotary Nut Case Join Date: Jan 2009 Location: Cibolo, TX
				Rep Power: 17  |
			Welcome,  Porting also is determined by the type of induction you want to use as well, some types of induction don't like port overlap so massive porting is not always the best way to go.
|  02-22-2009, 03:52 AM | #5 |
				Rep Power: 0  |
			hav 48mm ipa carb.
