Old 02-20-2009, 10:04 PM   #19
Brent
Sua Sponte
Brent's Avatar
Car looks good man! I like the dog pictures. Is your wideband 02 bung at the bottom of your downpipe? Only reason I ask is I see your LC-1 is mounted in the engine bay. If you run the sensor back the car and up through the tranny tunnel where the shifter comes through(of course make sure you wrap the wire so it isn't pinched as it comes through) to the interior, you will expose the actual LC-1 sensor to much less heat and prob. prolong it's life. I wrapped mine in thermal wrap just as overkill and secured it as far away from the tranny as possible. The actual sensor is now mounted underneath the tranny tunnel cover in the interior... basically behind where the ash tray is.
