#31 |
Rep Power: 20 ![]() |
Which temperatures?
The recent temperatures outside were around 30F or as low as 7F. The temperature when the car starts behaving like it's got a vac leak is 173.8F. I data logged a recent trip to Radford VA when it happened and this is what I have: (I adjusted the idle to be high so I wouldn't stall out--when the symptoms occur the car idles at about 1200-1500rpm. When the symptoms are not there the car idles at 2000-2500rpm) At 3478RPM I see: 7.2 Lbs/min 3.0 inHg AFM Air Temp is 34.2F Intake Air Temp is 42.1F Injector P/W is 8.73ms NB O2 is 0.03 Volts Coolant Temp 173.8F I can pull some of the logs I've taken of the car during the symptoms if it would help. I'm waiting on a garage to open up before I do any more testing.
#32 |
What color is the smoke on startup?
Coolant seal is a possibility, although, your engine temps should rise if thats the case (unless the car dies before it gets a chance to). Have you had issues w/ coolant level in the radiator lately? |
#33 | |
On a side note, I have details on when the engine was installed and by who. The engine was installed by Wayne's Imported Automotive and as far as I can tell was completed on Aug. 6th 1997. They list an entire engine as a part for a cost of 2150 and has the part number of E008-99-008R which I think means it's a re manufactured engine, maybe rebuilt, but I doubt that shop knew about it. As a side note to discussion is 1997 late enough in the game to have the newer 1 piece Apex seals in it or would it contain the 2 piece Apex seals, or is there just no way to tell until I look at them through the exhaust ports/ break open the engine?
#34 |
Just break open the engine and look at what's needed and not needed. That would tell you the condition of the engine much better than just guessing. It's better to be sure and make sure you get things right the first time. It's also much cheaper.
#35 |
If I had a little extra money I would in a heart beat. But I don't so I'm only trying to buy what I need to.
I'm going to be tearing down the car tonight and inspecting the exhaust ports to see what's up. I should know alot more by then.
#36 |
Alright so I checked the rear rotor. It's not coolant. It's just alot of gas. so much so that it was pushing it into the thermal reactor and half way down the exhaust. It was just a heavy gas mixture with some oil mixed into it. When I checked the coolant it was perfectly clear without and any obvious change in color. The oil looked like oil and not milk chocolate.
So what could cause a huge vacuum leak on the rear rotor? So much so that it effects it at operating temperature?
#37 |
Well if you said it was fuel coming out, then its probably a stuck injector and not a vac leak at all.
Also, a side note on your engine info. 2150 sounds a bit "cheap" for a reman engine installed, even back in 1997. Remans are tagged and you should be able to see this tag on the front cover area (if looking from the front, it should be visible near the CAS and below the alt, tucked in a little), or possible on the rear iron on the drivers side. Either way, if you dont see a tag, I'm betting on it being a used motor, bought from a salvage yard and installed. Not that its a bad thing, just something to consider. You may have more miles on that engine than you think... |
#38 | |
| Tags |
| coolant seal failure, egr block off, rtv, vacuum leak |
