Old 03-12-2008, 03:10 PM   #1
AwakenNoMore
AwakenNoMore's Avatar
AwakenNoMore is on a distinguished road
Instrument cluster illumination problem
Cluster stopped lighting up last night in the jack in the box drive through. everything else works, the fuse is good and when i tried to install a different headlight switch it started smoking . . . please help, need to see my gauges even if its a band-aid fix until i get the TII on the road. (s4 n/a)
1993 VR Touring, motor built by Arizona Rotary Rockets.
AwakenNoMore is offline   Reply With Quote
Old 03-12-2008, 04:02 PM   #2
My5ABaby
My5ABaby's Avatar
Check the wiring harness going to the headlight switch. If you burned up a 2nd headlight switch there may be a problem with the harness.
Old 03-12-2008, 07:45 PM   #3
J-Rat
J-Rat is on a distinguished road
See if you can trace the burning wire back.. That might lead you directly to the problem.
Rat
1988 10th Anniversary
554 RWHP, 395 RW Torque
10.7 @ 126!
owner:
www.azrx7.com
Engine built by ARIZONA ROTARY ROCKETS
www.azrotaryrockets.com
J-Rat is offline   Reply With Quote
