Old 11-10-2008, 09:09 AM   #76
rotorhead87
Rotors > Pistons
rotorhead87's Avatar
Now since that I had the motor ported along with the manifolds, I might as well go ahead and have a throttle body modification done. If you ever get a chance or have seen the differences between the brass throttle plates of the 13BT and the 13B-REW you'll notice a big difference. The REW TB has two big throttle plates in the secondaries and one small throttle plate in the primary, as for the 13BT all the plates are of similar size to the small plate in the REW TB. As you all know already that I'm trying to flow large amounts of air efficiently to feed the motor. Well any ways here at the shop JRFP started to bore out REW TB primaries to have all matching size plates in the primary and secondaries. The draw back of this modification was that I had to buy two FD TB because I could not find anyone that would sell the same exact size brass plate we were searching for. I ended up buying a good used FD TB from Herblenny and stripped TB from an other FD owner in Gainesville, FL awhile back. With this modification it help with the airflow by probably enhanced the primary size by 30% larger.
Here is the original plate on the left and the new plate installed
The old plate laying on top of the new one just for you all to see how much the size difference is.
From the inside
The FD throttle body all polished on the outside and the inside.
The the throttle body installed onto the motor.
Sorry everyone about the really crappy pictures, but I hope you enjoy.
***UPDATED 06/15/2009***
Old 11-10-2008, 08:40 PM   #77
RotaryXperiment
RotaryXperiment is on a distinguished road
coming along really nice. now u need some elf/total oil in there ha!
RotaryXperiment is offline   Reply With Quote
Old 11-10-2008, 09:23 PM   #78
rotorhead87
Rotors > Pistons
Is that oil any good? Its the first time I've heard of that product brand.
Old 11-10-2008, 09:50 PM   #79
need RX7
Clean S4 Nutswinger
need RX7's Avatar
Comin' along real good. This thing's gonna be a beast when it's done.
Old 11-12-2008, 03:14 AM   #80
Teenwolf1393
Teenwolf1393 is on a distinguished road
hey rotorhead, looking good . hopefully your motor treats you right
next time im in Port st lucie you gotta give me a ride.
Teenwolf1393 is offline   Reply With Quote
Old 11-12-2008, 06:25 AM   #81
SpooledupRacing
Guest
Posts: n/a
WOW.. very nice man.. looks GREAT.. keep up the good work!
Old 11-12-2008, 04:20 PM   #82
rotorhead87
Rotors > Pistons
Thanks everyone for the great compliments.
I feel confident that my motor will be good to me for a long run. That just because my builder built many 24hr 12A race motors that never see below 5,000 RPM. Definitely man next time your in town it would be nice to meet you and take you for a speed run. Hopefully it'll be running and have it's 2,000 mile engine break-in period completed by the time your back. Just keep in touch
Old 11-14-2008, 09:15 PM   #83
rotorhead87
Rotors > Pistons
Nothing crazy. The shop finally had an open slot for my car to begin swapping over all the goodies. These are just pictures of the car on it way to the shop.
I know I stole the idea of hanging the piston off the rear, but I thought it was the coolest idea. From what I heard Honda guys say "That's messed up man" about it. Technically I did get the piston out of a Honda.......push-mower.
Old 11-19-2008, 08:47 AM   #84
rotorhead87
Rotors > Pistons
Alright this where it begins to get alot better. Since I already had all the suspension parts preassembled with new energy suspension and delrin bushings along with the custom coilover kit, it was all just bolt-in and go. Within the first couple week of my car being at the shop I prepped for the installation. I ended up pressure cleaning and degreasing areas that have major dirt/grease build-up and washing the entire underbody to remove the 20years of collecting road debris.Plus theres nothing worse than working underneath a car and getting dirty in your eyes. Along with all the suspension part out it probably would be wise to go ahead and upgrade the brake system...gotta be able to stop when shes haulin'. I shopped around and tirerack had a close out deal on powerslot rotors. Well I ended up purchasing powerslot slotted brake rotors for all four wheels. As for pads I didn't want super performance pads that were extrememly harsh on the rotors also I didn't want loud pads either, so I ended up getting a set of EBC "Red stuff" ceramic brake pads. Just to top of the brake system I went ahead and bought stainless steel brake lines from mazdatrix for all four corners. While redoing the front brakes I was noted that it would be good time to replace the tired out front wheel bearings since they were kinda grinding already. By the time I knew it the car already had pretty much a brand new suspension and was noticably lower.
I didn't get a chance to take alot of pictures but I'll add more pics to this post once I get a chance to snap a couple.
Old 11-19-2008, 10:55 AM   #85
Is that a new custom auto-camber adjust band you got there??
The wheels look good... I'm a fan of the gold and red, well... gold on anything really
Old 11-23-2008, 10:57 PM   #86
s4.5 turbo gxl
s4.5 turbo gxl's Avatar
s4.5 turbo gxl is on a distinguished road
this is one nice well documented build thread. Keep up the good work. bet you cant wait to get it on the road.
s4.5 turbo gxl is offline   Reply With Quote
Old 11-23-2008, 11:57 PM   #87
rotorhead87
Rotors > Pistons
Heh Thanks! I try to keep it neat for fellow rotorheads to easily refer to. As everyone can probably tell by some of the pictures I'm kinda breaking my chronological order of occurrance during this build. If figured I'd just go by sections like to stock==>to repaint bay==>to motor===>to suspension==>to etc,etc....OooOHhh yeah I can't wait just to hear her purring for me again, I've been balled up in major boost withdraws going onto 3.5 years now.
Old 11-29-2008, 01:18 PM   #88
rotorhead87
Rotors > Pistons
Now for my exhaust. It basically a custom turbo-back 3'' inch splitting into dual 2.5'' inch stainless steel piping. It made from a modified RacingBeat downpipe connecting into an oval Borla XR-1 racing muffler. Exiting the muffler the pipe split into a 2.5'' inch Y, then exiting into the two OBX mufflers. I had the cat removed since it was a power restrictor and we have no emission regulation here in FLA. As for the JGS wastegate since it was a V-band, it won't simply work with the HKS manifold. JR Fabrication and Performance made me a custom adapter fabricated to fit the wastegate and plumb the WG with a Burn's flex pipe back into the exhaust, instead of venting it into the atmosphere. While everything was out, it was best to go ahead a purchase all the rubber hangers from Mazdatrix to ensure a proper fitment. I haven't had a chance to hear it yet, but I'm sure it'll sound good. I'll post up vids/soundclips once shes running, but for now just pics everyone.
Let me know what ya think?
Old 11-29-2008, 02:20 PM   #89
Kane
All about the O2
Kane's Avatar
Kane is on a distinguished road
Yep - those are some big pipes.... I like it.
My 2007 Turbocharged RX8
Kane is offline   Reply With Quote
Old 11-30-2008, 03:39 AM   #90
Teenwolf1393
shes coming along quite nicely. i cant wait to hear it
