Old 11-03-2008, 11:10 PM   #1
ArtOfRuin
Magic Spinning Triangles
ArtOfRuin's Avatar
ArtOfRuin is on a distinguished road
eBay Miata short throw shifter
The shifter bushings in my N/A S4 are shot. I am considering getting an eBay Miata short throw shifter rather than just replacing the bushings. However, in this thread (http://www.rotarycarclub.com/showthread.php?t=4631), some of you guys say a short throw will wear out the transmission more quickly. I assume the transmission has 98K miles on it, given the shifter sloppiness (the car has a rebuilt 13B with 10K miles on it). The S4 will be a summer car and autocross car. So, do these really wear out the transmission more quickly, or is it only with more vigorous driving? And what should I look for, should I decide to get a short throw on eBay?
'87 Mazda RX-7 GXL: Solo E Stock-bound
'98 Subaru Impreza: The Daily Beater
ArtOfRuin is offline   Reply With Quote
Old 11-03-2008, 11:41 PM   #2
I'm sorry I posted that, now that I think back on it, I think it was probably more the guy switching to W90-140 weight oil and trying to drive better than the short shifter itself.
Remember, even if you get the kit, you still might need the little boot in there that might be torn up ( the one that slips over the shifter and bolts to the trans) it's $29 from Mazdatrix, I just replaced two.
I also notice that half those shifters come with only a top bushing, but not the bottom one, so what I would do is: order it, take apart the shifter, look at what bushings you need, etc, and order the little boot and if you need the lower bushing.
PS: sorry to throw you off bro.
EDIT: I also read somewhere that N/A transmissions seem to last around 130,000 miles, so I think that you got nothing to worry about!
Old 11-04-2008, 08:22 AM   #3
Pffft! Mine has 140K on it, over 10K behind the TII engine!
Regarding the shifter: I have had a Miata Short Throw shifter in mine since I did the turbo swap. No issues. Replaced all the bushings, and just replaced the boots. Also, realize that the short throw shifter is not really any shorter in height than the stock shifter.
Here is a pic of mine: Miata Short Throw shifter, 5spd RX-8 knob, IndyParts shifter and e-brake boots.
Old 11-04-2008, 08:34 AM   #4
SpooledupRacing
Guest
Posts: n/a
Yeah my guy Alex (RotaryXperiment7) has a ebay miata short throw... its nice I have heard and I plan to so it with mine..
Old 11-04-2008, 06:44 PM   #5
ArtOfRuin
ArtOfRuin's Avatar
Thanks for the advice. The shifter right now feels like I'm rowing it through jelly!
Another question: Aluminum, or steel?
Old 11-04-2008, 07:17 PM   #6
RotaryXperiment
RotaryXperiment is on a distinguished road
i HAD one, wasnt too bad. simple install as well. im using the corksport one now.
RotaryXperiment is offline   Reply With Quote
Old 11-05-2008, 09:52 AM   #7
jerd_hambone
Senior Member/Lounge Rat
jerd_hambone's Avatar
I have an $80 Ebay FC shifter. It's been in for almost 15k with no problems so far.
But I had to mill out my stock S5 shifter to get it to fit
1986 Luxury Package
1987 Luxury Package (sold)
1988 SE (sold)
1989 GTU (sold)
1990 GTU (sold)
jerd_hambone is offline   Reply With Quote
Old 11-05-2008, 11:46 AM   #8
See, to me that is not a good deal. I paid $35 for my eBay Miata shifter, and it dropped right in. No modifications.
If it is an FC specific shifter, there should not be any extra milling required.
Old 11-05-2008, 05:29 PM   #9
jerd_hambone
It was, but I think it was made for an RX-8 knob. The hole in the shift knob wasn't big enough to go all the way down
1986 Luxury Package
1988 SE (sold)
1989 GTU (sold)
1990 GTU (sold)
Old 11-11-2008, 10:40 PM   #10
fc nut
member
fc nut is on a distinguished road
Post
i just ordered a miata shifter and was wondering,will my shift nob fit it?
leaving my carbon footprint....one start up at a time
fc nut is offline   Reply With Quote
Old 11-12-2008, 08:13 AM   #11
The Miata shifters use the same thread pitch as S5 FC's, FD's, and RX-8's. So, by judging from your avatar pic, you have an S4 and therefore will need a new knob as well.
Old 11-12-2008, 08:25 PM   #12
SouthSideSlider
SouthSideSlider's Avatar
SouthSideSlider is on a distinguished road
simple awnser is no. miata's use a 10x1.25 threads
2000 Acura Integra GS: daily driver
1990 Mazda RX-7 GTU: parts car.
1986 Mazda RX-7 base: under the knife.(no sunroof!!!)
1989 Volvo 745 turbo: B230ET,19T turbo,850 Turbo injectors,HKS Manual Boost Controler,Port/Polish,Oversized valves,titanium valve springs,M-Cam,G80 locker,modded AW71 transmission.
SouthSideSlider is offline   Reply With Quote
Old 12-26-2008, 06:57 PM   #13
fc nut
member
Post
i had the miata shifter in for a while to see how i liked it and i had trouble with the 2nd to 3rd shift.it would grind in the 1-2,2-3 shifts , its like it needs a shim of some kind to raise the shifter up a little bit.my next shifter will be rx-7 specific.
Old 01-09-2009, 09:47 AM   #14
Kelton
Fried Chicken
Kelton's Avatar
Kelton is on a distinguished road
I've ordered a couple of short throws from egay, and all the ones I gotten are either missing a bushing or doesn't have any whatsoever....so either A. Make a Bushing/ Buy One or B. Make your own short throw with a Cutting Wheel and Welder.
87' GXL Rx-7
97' S10 Ext Cab~DD
Kelton is offline   Reply With Quote
