Out of Nickels and Dimes
I've seen this happen if there is a big intake or vacuum leak. Too much unregulated air into the engine causes it to die when the ECU switches to the AFM after startup.
1988 GXL |
#2 | |
Rick's Speed Shop
Look around the intake and see if you don't have a loose clamp or something of that nature. Sounds like you have a large leak.
We Make Custom Shifter Boots! Check Out the Vendor Section!
Rick's Speed Shop ![]() |
