Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Rotaryshack
Rotaryshack www.rotaryshack.com (CA) Specializing in carbs, custom turbo kits, 1gen rx7 parts
Old 10-23-2008, 10:45 AM   #1
730RWHP12A
used parts section for sale cheap! check it out
used parts for sale section cheap!!! remember its a buyers market so all prices are negotiable! also if you dont see a part listed you can always request it
i will update this list weekly, so check back often to see if there is anything you want
13B racingbeat exhaust heade--- like new $180.00
used low mileage GSL-SE 13B motor with warranty $500.00
used 12A that runs with oil leak $300.00
used JDM FD 5 speed transmission, does not grind works great $400.00
nikki carb, race prepped $300.00
de-smogged 12A nikki intake manifold(egr and coolant passages have been welded up to reduce intake temperatures) a great power upgrade for cheap! $80.00
black sunroof latch assembly, round dial type( 80-83).......$60.00
exterior door handles fits 79-85 cars.....$25.00
exterior door handles fits 86-92 cars.....$60.00
84-85 power window switches..... $40.00
quiet good condition 79-80 transmission with warranty $350.00
grey 84-85 center armrest assembly, good condition, from a GSL model....$40.00
glass sunroofs avail, 80-85 ppg mfg.. good condition $200.00
new GT47-80 garret turbo.......$2,000
gsl=se afm (used)$40.00
msc engine rotors, housings available, please inquire within(pm)
turbo 2 intake manifold inlet adapters(2-1/2 straight inlet)..... $80.00
turbo 2 intake manifolds uppers and lowers available $60.00-$120.00
gsl-se suspension complete changeover includes everything you will need to convert your car ! brakes, rotors have approx. 2,000 miles, front struts were also replaced 4,000 miles ago with original kyb inserts.......$1,500
complete 85 12a non turbo motor.. was running great when removed for a turbo swap.. guaranteed to run good!!!..........$650.00
several msd efi fuel pumps.............$100.00 each
msc 91 convertable parts, air bag, turn signal switch, visors,ignition switch
fully built pinned bridgeported 13B 4 port( early type) 3mm apex seals new rotor hsgs, all new seals and springs, new oil o-rings and carriers, one year warranty $3,800
os geiken clutch/ flywheel setup, like new twin plate style for turbo 2 $800.00
os geiken clutch flywheel setup, missing pressure plate twin plate style for turbo 2 $300.00
rotaryshack.com
