Evil Club Mod
Additional Info
Steering Power (RPM-Sensitive) Steering Ratio - 17.4:1 Transmission M Type (N/A, 87-92) - Clutch inside diameter = 150 mm (5.59 in) - Clutch outside diameter = 225 mm (8.86 in) - 1st = 3.475:1 - 2nd = 2.002:1 - 3rd = 1.366:1 - 4th = 1.000:1 - 5th = 0.697:1 - Reverse = 3.493:1 - Final Drive = 4.100:1 - 1st ---> 2nd Synchronizer Diameter = 65 mm (2.45 in)M Type (N/A, 89-90 GTUs Only) - Clutch inside diameter = 150 mm (5.59 in) - Clutch outside diameter = 225 mm (8.86 in) - 1st = 3.475:1 - 2nd = 2.002:1 - 3rd = 1.366:1 - 4th = 1.000:1 - 5th = 0.756:1 - Reverse = 3.493:1 - Final Drive = 4.300:1 - 1st ---> 2nd Synchronizer Diameter = 65 mm (2.45 in) R Type (Turbo, 89-91) - Clutch inside diameter = 160 (6.3 in) - Clutch outside diameter = 240 mm (9.4 in) - 1st = 3.483:1 - 2nd = 2.015:1 - 3rd = 1.391:1 - 4th = 1.000:1 - 5th = 0.719 - Reverse = 3.288:1 - Final Drive = 4.100:1 - 1st ---> 2nd Synchronizer Diameter = 76 mm (2.99 in) - 2nd ---> 3rd Synchronizer Cone Diameter = 65 mm (2.45 in) R Type (Turbo, 91 Infini IV Only) - Clutch inside diameter = 160 (6.3 in) - Clutch outside diameter = 240 mm (9.4 in) - 1st = 3.483:1 - 2nd = 2.015:1 - 3rd = 1.391:1 - 4th = 1.000:1 - 5th = 0.719 - Reverse = 3.288:1 - Final Drive = 4.300:1 - 1st ---> 2nd Synchronizer Diameter = 76 mm (2.99 in) - 2nd ---> 3rd Synchronizer Cone Diameter = 65 mm (2.45 in) Rotor / Seal / Spark Plug Info. (89-91) Compression Ratio = 9.7 N/A, 9.0 Turbo Brakes (89-92) 15 inch wheels (Standard Brakes) - Cast Iron Single Piston Calipers with an 8 in vacuum servo - Ventilated Front - Solid Rear Disc - Disc Diameters = 276 mm (10.9 in) front, 261 mm (10.3 in) rear - Pad Areas = 64 sq cm (1.9 sq in) rear - 15/16 inch wheels - Front Aluminum Four Piston Calipers / Single-Piston Floating Calipers (9 in vacuum servo) - Caliper Weight = 3.2 kg (7.1 lb) - Pad Areas = 94 sq cm (14.6 sq in) front, 64 sq cm (9.9 sq in) rear - Disc Diameters = 276 mm (10.9 in) front, 273 mm (10.7 in) rear |
