Old 10-15-2008, 05:19 PM   #1
Default Gutting or Removing the Thermostat
Well, I asked before and I didn't really get a reasonable response.
Why are you NOT supposed to gut or remove the thermostat?
It seems to me that if there was no Thermostat the water will continually go through the radiator at all times. Mate it with an aftermarket thermo switch and you would turn the Efans ON at any temperature range and ensure that the car is being cooled properly. Right?
The only problem is that everyone says don't do it but they never say WHY. I trust you all (which is why I haven't done it) but is there more to the reasoning besides just "no, don't do it?"
Old 10-15-2008, 08:40 PM   #2
SpooledupRacing
Guest
Posts: n/a
Default
IMO the theory is that if you don't have a thermostat it wont build up the appropriate amount of heat in order to get warm air out of the vents to keep u warm in the cold or to defrost your windows.
Another things is some people says it wont let the engine get warm enough to get up to temp to put it into the open loop (or is is closed lol I get them mixed up)
Old 10-15-2008, 08:59 PM   #3
RotaryProphet
Default
The engine requires a restriction in order to build up water pressure, which helps eliminate hot spots in the engine; and serves to hurry along water vapor that will have a tendency to sit over the hot spot where it formed instead of allowing water through.
If you remove the thermostat, install a restrictor in it's place to allow the pump to build up some pressure. The exact size of the restrictor hole needed depends on the size of the engine, water pump flow rate, water pump RPM, heat load, and a ton of other things, but a 1/2" or 5/8" hole would be a good start for a rotary.
Old 10-16-2008, 06:49 AM   #4
My5ABaby
My5ABaby's Avatar
Default
The way I see it, the thermostat is there to regulate the temperature within a set amount of degrees. Without that regulator, your temperature is whatever your system allows. Running too cold (which could likely happen) is not a good thing. Unless you're pushing a ton of hp and creating a lot of heat or something, I see no point in removing it. Hell, I just replaced my presumably original one after 22 years on the car and prior to replacement the presumably original system was cooling the car adequately in most situations.
Community Service Manual
RotorWiki
Old 10-16-2008, 06:57 AM   #5
SpooledupRacing
Guest
Posts: n/a
Default
IMO its just a replace deal.. not remove.
Old 10-20-2008, 11:28 AM   #6
88turboii
destroy, rebuild, repeat
88turboii's Avatar
Default
i drove my old TII for a while on a stuck open t-stat, it would take forever to warm up, and temps usually be around 1/8th onthe gauge. The coolant seals went out a little while after.. food for thought
Old 10-20-2008, 11:44 AM   #7
Default
If the engine never reaches operating temperature (t-stat removed), it will not go into closed loop mode and will run rich all the time.
At least that is what I was told.
Old 10-21-2008, 06:19 AM   #8
Cp1
Cp1's Avatar
Default
the real reason:
Ive operated a supra race built car for a long time without a thermostat with no ill effect on the motor however the reason it is there is allow proper heating of the motor. the colder the motor is the poorer gas mileage and greater amounts of hydrocarbons are released effectively make the t-stat an emissions control, and quite possibly the best emissions control on your car. i have a number of graphs showing engine operating temperature and emissions, so companies strive to get the motor running as hot as possible without the risk of damage to meet emissions and mileage requirements. the other main factor or result of this is that because the tolerances used to build your motor are derived directly from the desired operating temperature, ie: thermal expansion, if your car is constantly running too cold the tolerances are too far out to ensure smooth operation and transversely if you are consistently too hot... well you know what happens!
Old 10-25-2008, 09:51 AM   #9
Default
I've run my FC with a gutted thermostat and NO thermostat.
For day-to-day street driving, it just takes a little longer to warm up.
Mind you, I live in Hawaii with relatively warmer ambients.
It just takes a few more minutes to get to temp (above 160F).
I would NOT recommend this if you see anything close to freezing temps.
For racing, when the engine sees sustained revs, you need the restriction to minimize hot spots, as others have mentioned.
For street driving, you just eat up more gas due to the engine staying colder longer.
Old 11-17-2008, 10:32 AM   #10
retaliate1st
retaliate1st's Avatar
retaliate1st is on a distinguished road
Default
and your add coolant warning light will stay on...
retaliate1st is offline   Reply With Quote
Old 11-17-2008, 10:40 AM   #11
SpooledupRacing
Guest
Posts: n/a
Default
I think if the system is properly full and no air pockets this will not happen.
Old 11-17-2008, 02:11 PM   #12
Signal 2
Viable Fossil
Signal 2's Avatar
Default
IIRC, there is also a route that allows coolant to bypass the radiator and return directly to the motor. Isn't it always be open without the t-stat?
Jim
VR R1 FD
Old 11-20-2008, 12:35 PM   #13
retaliate1st
Default
From experience, I beg to differ. I had my engine rebuilt by what I later realized to be an inexperienced shmuck. When I picked up the car the add coolant alarm/light stayed on constantly. It was completely full w/ no air pockets. (I drained and refilled it 3 times...)
800 miles later: coolant in the engine; rebuild. I discovered my lack of thermostat, put one in, and ever since the alarm / light has been off.
just my $0.02
Old 11-21-2008, 08:13 AM   #14
staticpat
Rally Fanboy
staticpat's Avatar
staticpat is on a distinguished road
Default
Even the mazdamotorsports tech section recommends this.
Originally Posted by mazdaspeed
Water Pump
Water Pump/Thermostat
If you are using a stock (cast-iron) water pump, we recommend "gutting" the stock thermostat, leaving just the thermostat casing. Because some "restriction" is helpful, generally removing the thermostat is not as effective as using a gutted thermostat or restrictor. It is also important to plug the thermostat housing's water bypass. This can be done very easily by tapping the hole (1/2" pipe tap) and installing a plug
staticpat is offline   Reply With Quote
Old 11-21-2008, 08:42 AM   #15
SpooledupRacing
Guest
Posts: n/a
Default
just my $0.02
when I bought my rx7 it had no t-stat in it. no buzzer ever came on. So I know from experience that the buzzer wont go off without one.
Also dont u think reted would have mentioned that since he just said that he has run one with a gutted one and without one all together.
Ad Management by RedTyger
