| Rotaryshack www.rotaryshack.com (CA) Specializing in carbs, custom turbo kits, 1gen rx7 parts |
#1 | |
Rep Power: 21 ![]() |
About the T5 adapter.
The T5 adapter is only good for the Ford splines im guessing, but the options i have found for the T5 make interested in the GM transmissions. Namely what i can get with my choice of gearing. I want to get as close as possible to the Mazda Comp. transmission ratios, which Richmond sells for the Super T10. But it looks to be only the GM 1-1/8" 26 spline. Do you know how different the GM transmission is? I might need to discuss in another thread about gear choices because there are some T5 options that may or may not work, since they are using 5th gear as 1:1 and sadly, are more money...
as per the listing Quote:
