| RX-8 (2004 - Present) All things to do with RX-8 |
Can you get the car to run? If it does run, put a volt meter on the battery posts. This will tell you the charging voltage which should be 13-14 volts. Out of those voltages and you have a charging system problem (alternator, voltage regulator).
Notice any ground wires bad/disconnected? |
