![]() To all of the above replies! Most likely you will have blown cooling seals to start with. How come you overheated? Low on coolant or just racing your motor for a long time? Check your cooling system for bubbles and if you see any milky-ness or foam u got blown cooling jacket seals. Since your rebuilding it shouldn't be a problem if your motoris still running but you might hav to replace a front or center iron. The seat fo the cooling seals are very thin in some areas causing them to crack and become unusable.
--^v--JunpoweR--^v-- "90 GTUs Crystal White *GT35 WB TA Project* "90 GTUs Brilliant Black *Restoration* 1984 GSL-SE *Daily* |
Bookmarks |
Thread Tools | |
Display Modes | |
