possible S5 TII OMP problem
S5 TII, fresh rebuild
car runs like shit when u try to load it up a little bit, which seems to be OMP problem....i checked resistance on 6pin connector and there is none, assuming OMP is really bad.... question is : can i use some resistors and 'cheat' stock ECU to run ok without OMP or is my only solution to find some good OMP? |
#2 | |
Rep Power: 21 ![]() |
I looked at the specs for both the NA and TII oil pumps and here are the differences:
NA pump diameter x width of rotor: 50mm x 17.5mm TII pump diameter x width of rotor: 50mm x 12.5mm You may have a hard time using an NA OMP pump if you look to replace it. Let me know if you want to trick the ECU or get aa new OMP.
#3 | |
![]() I am talking about OMP, not oil pump..... |
#4 | |
This problem just doesn't sound right. Do you have any more info on the engine?
#6 | |
Last thing i tried was unhooking OMP on working car and it started to behave exactly same like car with problem. Then i measured resistance/voltage on OMP of working car and on other car as well - working car had good results, problem car none. Thats the point where i found OMP (or its wiring) to be faulty and thats why it goes into limp mode. With some luck, i might get working S5 OMP from friend today and will hook it up friday to see if its all whats wrong... Will let u know |
have spare OMP from friend, will try to hook it up today and let u know results.....
You cannot fool the stock ECU unless you get a microcontroller.
The problem is that there's a feedback circuit which tells the stock ECU what position the stepper motor is in. This is the big problem. It's easy to fool the stock ECU into "seeing" the 3 stepper motors (via resistors), but how do you fool the feedback circuit? -Ted |
#9 |
Replaced OMP today, problem fixed....
#10 |
well, you can either:
A: Buy the RTEK S5 omp canelling chip for $100, then get a S5 OMP block off plate, gasket, and RTV to seal it.. or, B: Get another used S5 OMP, and refurbish the lines courtesy of a guide on the evil forum.
