#31 |
Omg, monkey please stop.
Your wastegate is working fine from what I have read, the problem you are having is the ported wastegate on top of a 6 port motor. Stock I'd say you are right on the money boost wise, but you may experience a fall off on peak boost higher in the rev range close to redline.... maybe, I am not certain on that though. It comes down to this, that wastegate is venting to much exhaust, and with no controller, there is no way to stop it. Invest in a good boost controller (you can re-use them on multiple turbo / car setups.) It'll keep the wastegate shut until it senses max boost, then slowly actuate to maintain the desired boost pressure, something you can't do with the stock turbo setup. Since it is ported, then you shouldn't experience any boost spike, but without a controller, you'll see less boost than you want. I have two turbo's sitting outside. S4 and S5 if you want pics of the wastegates and the actuators. They either work or they don't 99 percent of the time. Get yourself a controller, get boosting, and enjoy. ![]() -Maniac |
#32 | |
#33 |
I wasn't trying to sound like I was bitching at you, sorry if I came off that way. I was really tired and wasn't really paying attention to what I wrote.
Also worth noting and something I forgot to add. With a boost controller, it will keep the wastegate closed until desired boost pressure is achieved. The stock system just creeps to 10 (if you didn't port the wastegate that is). So the end result will be a fatter more useable powerband. You'll see quicker spool and a lower RPM positive pressure threshold. |
#34 | |
^Right on BoostManiac, thats why I need a EBC...I hit 10 psi but it takes awhile ie; top of second.
#35 |
thanks maniac thats what I wanted to hear... in your experience what's a good one that isn't going to be too much money for what i'll be using it for (getting 4-5 more psi) ?? I understand I can use it for multiple setups but none of those are in the even remote future... thanks again... should I shy away from MBCs??
#36 | |
BUT There is a side effect that you won't notice until you ride in a car equipped with an EBC. The wastegate still opens a little bit so the transient boost response is still not as fast as it can be, AND you have to fiddle with it to get it set JUST right, meaning multiple times of getting in the car, boosting, getting out and adjusting under the hood (or in the car if you route some vacuum lines into the cabin), boosting some more etc etc. You need to check the boost in a higher gear to make sure it won't creep under high RPM full load past your preset point. We used one on an FD once to just see how well it worked and we ran into a small (thank god) oopsie. Someone had completely shut the MBC not knowing what it was when it was off the car. We put it back in and boosted in second gear. This car was tuned for 14 - 16 psi, we recorded a full 26 psi on an instantaneous boost spike since the wastegate would not open. He lifted the throttle as fast as he could and we heard a massive explosion. Turns out the Rubber line connected to the BOV had ruptured while trying to vent this pressure and literally blew the BOV off of the piping. It was hanging down by the turbo by the vacuum line. If you get a MBC, just please be careful, we got lucky and he had a fast foot, otherwise it would have been rebuild time. As for the EBC, anything commonly found will work great on an FC. I always liked the ones using the fuzzy logic to predict spikes and keep the boost steady. I am sure you can find one used somewhere dirt cheap, just make sure to get the instructions for installation and setting it up. Also, be prepared to do Bar conversions if you get one from overseas. Here are a few on this page you can look at. The prices are high, but they are worth their weight in gold IMHO. They also have features that a MBC just can't do, and that MIGHT mean the difference between flawless boost response and accidental rebuild time. http://corksport.com/store/category/5pjf/turbo.html Take your time to research the pro's and con's of each and then make your choice based on your budget / setup. Since I am mostly worried about low end production and a fat useable powerband, I am ALL about the EBC's, but a MBC will also work if you are short on cash for the time being and just need to put some trash talking friends in your rear view. ![]() -Maniac EDIT : what you will be using it for would be perfect either way. I would suggest looking around for a used one with a complete harness and instruction manual. If you need a MBC on the super cheap though, I think I still have my schematics for the Home Depot special. Don't laugh, it really does work. That was the one that nabbed us the 26 psi. It costs about 5 bucks. Just remember the old adage, cheap usually costs more. Last edited by Boostmaniac; 07-31-2008 at 09:52 PM. |
#37 |
Yeah look for a nice use one on a local forum.
